Persistent leaky valve cover on LA
Small Block Mopar Engine
  1. Bill Crowell
    Bill Crowell FABO Gold Member FABO Gold Member
    871
    381
    Oct 16, 2007
    Diamond Springs, CA
    Local Time:
    1:39 AM
    Original sheet metal factory valve covers, which are clean. Using the Moroso hold-downs. I really don't want to have to permatex the valve cover to the cylinder head, not only because it is redneck, but also because it is so hard to get the permatex off later when replacing the gasket, and because you can't avoid getting some of the permatex into the pushrod holes when you scrape it off the head.
    I tried straightening the valve cover and so did my mechanic. He thought he got it straight, but it still leaks. Would you guys have any words of wisdom for me before I buy some alloy valve covers?
  2. fklskv
    fklskv Well-Known Member
    1,111
    584
    Aug 14, 2011
    Lackawanna, NY
    Local Time:
    4:39 AM
    What worked for me was sealer on gasket to the valve cover and stop tightening the bolts like they were lug nuts
  3. 4spdragtop
    4spdragtop FABO Gold Member FABO Gold Member
    28,934
    8872
    Aug 28, 2009
    Wasting time here
    Local Time:
    3:39 AM
    There are permanent reusable vc gaskets. Summit or Mancini I think
  4. furrystump
    furrystump Well-Known Member
    1,022
    640
    Nov 13, 2004
    Local Time:
    9:39 AM
    Glue it to the cover then softly tighten the cover down finger tight. Leave over night. Then tighten the rest of the way very lightly. A small dot of sealer on each bolt. You can remove and replace after that a bunch of times without replacing.
  5. B-onefan
    B-onefan Well-Known Member
    1,298
    88
    Oct 2, 2009
    Texas
    Local Time:
    3:39 AM
    Is it leaking in the center, bottom hole?
  6. brian6pac
    brian6pac Well-Known Member
    4,616
    3101
    Nov 15, 2016
    N.E.Ohio
    Local Time:
    4:39 AM
    Glue the gasket to the VC with 3M 08008 super weather strip adhesive, after it sets up it will never leak between the VC and the gasket. 1/2 the battle is over.
  7. Tooljunkie
    Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
    14,192
    13160
    Jul 22, 2017
    Manitoba
    Local Time:
    3:39 AM
    I have always only put sealant on the removeable part. Timing cover, water pump,whatever.
    Grease the side you dont want to stick.
    And valve covers no tighter than a nut driver. Even then may be a little much. May want to look closely for a crack too. BTDT
  8. mderoy340
    mderoy340 Well-Known Member
    2,306
    1072
    Aug 2, 2012
    Melbourne FL
    Local Time:
    4:39 AM
    Grease is the ticket.
  9. pishta
    pishta I know I'm right....
    17,009
    6651
    Oct 13, 2004
    Tustin, CA
    Local Time:
    1:39 AM
    rubber steel core gaskets.
    • Agree Agree x 2
    • moper
      moper FABO Gold Member FABO Gold Member
      15,709
      1841
      Dec 27, 2004
      eastern CT
      Local Time:
      9:39 AM
      Are the covers hitting the intake? Sometimes that will make them leak.
      This is how I do it. I only use the stock cork ones. the flanges and head surface have to be 100% clean of all grease and oil, including from your skin. Use a small amount of weatherstrip adhesive to glue the gasket to the tin cover. Place the cover in place, and start all the bolts by hand. Then, using a 1/4" drive wratchet and extension so you are really only using your wrist to torque them, start with the center bolt on the bottom. Snug it down but not fully. Then do the two lower corner ones. Then snug all three lower bolts up. Then do the two top bolts the same way. Snug them both, then tighten using only your wrist and the small wratchet. If the cover bends, you went too far. Doing them this way for 35 years - rarely a leak. Plus I've reused the same gaskets for years doing lash adjustments.
      Three main causes for leaks: oil or grease on the mating surfaces, the gasket is too stiff, or the fasteners were overtightened.
      • Agree Agree x 1
      • teringer
        teringer ase master hall of fame FABO Gold Member
        793
        165
        Feb 22, 2011
        kenly nc
        Local Time:
        3:39 AM
        check the head for core shift could have a low spot on vc sealing surface I have seen this on some
      • OL DODGE
        OL DODGE Well-Known Member
        207
        96
        Mar 25, 2012
        Fairview Park,Ohio
        Local Time:
        3:39 AM
        Amen to that ! Spotlessly cleaned surfaces bone dry to start off with. Cork gaskets adhered only to the cover. Bottom bolts snug .Then tops .Never over tighten. And make sure PCV valve is rattlely while you are at it.
      • AJ/FormS
        AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
        18,095
        6380
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        3:39 AM
        I agree on making sure your PCV system is working
        • Agree Agree x 1
        • H22A4
          H22A4 Well-Known Member
          1,842
          750
          Aug 4, 2006
          YVR
          Local Time:
          1:39 AM
          Search box at the top would also give you about 35 other tricks and tips to stop the leaking too.
        • pntastar69
          pntastar69 Well-Known Member
          1,474
          142
          Dec 28, 2006
          Gilbertsville, PA
          Local Time:
          5:39 AM
        • 70chall440
          70chall440 Mopar or No Car...
          284
          267
          Jun 9, 2018
          Yelm WA
          Local Time:
          1:39 AM
          Check the breather/PVC system, had a similar problem on a 440, added (read replaced) the breather and it was good.
