Pertronix for dual point distributor
Electrical and Ignition
  1. drewmac
    drewmac Well-Known Member
    353
    116
    Jun 7, 2012
    Lacey, Wa
    Local Time:
    7:19 PM
    I have an original dual point from my 273 Commando. Can you convert it to a Pertronix 2. also does anyone have or know where to find a rebuild guide/ instructions for that distributor (If I can't convert I'll rebuild it and sell)? It is just like the picture below I got off the internet.
  2. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    60,887
    27157
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    9:19 PM
    Send it to @halifaxhops and he has a Sun Distributor machine and can curve it any way that you want....
    • Agree Agree x 1
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      81,511
      61120
      Jun 7, 2010
      Georgia
      Local Time:
      10:19 PM
      I would not do that. That's an original CAST IRON HP 273 dual point distributor. They ain't fallin outta trees. I would buy a new reman, convert that and put a good performance curve in it, or just buy a complete performance distributor and leave the original alone. Pack it up and store it somewhere safe.
      • Like Like x 1
      • Agree Agree x 1
      • drewmac
        353
        116
        Jun 7, 2012
        Lacey, Wa
        Local Time:
        7:19 PM
        Ok. That is doable. I'll keep it as is. Thanks.
        • Like Like x 1
        • 67Dart273
          67Dart273 FABO Gold Member FABO Gold Member
          52,471
          21620
          Oct 14, 2010
          Idaho
          Local Time:
          7:19 PM
          If Pertronix makes a fit for the dual point it will bolt in and require no mods, so you could restore it back. But I don't know. You need to contact Pertronix or get whatever they call a catalogue
          • Agree Agree x 1
          • cudamark
            cudamark FABO Gold Member FABO Gold Member
            9,274
            1622
            Mar 14, 2009
            San Diego
            Local Time:
            7:19 PM
            I converted mine. You have to get the correct kit though, as most sites don't really list it by the distributor number for some reason. I had to verify which kit I needed by calling Pertronix. It ended up being a Pertronix 1 kit. I had to file one of the mounting holes a tad bigger to make the pickup plate fit properly, but, it was no big deal. It was a 1383 kit that I used on my stock '66 dual point.
            • Agree Agree x 1
            • halifaxhops
              halifaxhops It's going to get stupid around here! FABO Gold Member
              70,765
              41514
              Jan 20, 2014
              Hoppyworld, PA
              Local Time:
              10:19 PM
              They make one easy to install. Worth more stock actually. No advantage to doing it realy to flip it.
            • jazak5
              jazak5 Well-Known Member
              1,200
              600
              Aug 6, 2015
              NY
              Local Time:
              10:19 PM
              jazak5Well-Known Member
              1,060
              504
              Aug 6, 2015
              NY
              Local Time:
              5:40 PM
              well, after reading the articles in this site, I finally got it right I call Pertronix because their Email doesn't seem to work and voiced that with my phone call, HOWEVER the sales person was nice to deal with !!! This kit does not have a magnetic stator but uses the factory points cam to trigger the module .
              well no one seemed to post pics so here they are
            • cudamark
              9,274
              1622
              Mar 14, 2009
              San Diego
              Local Time:
              7:19 PM
              That number is for a '69 340 engine with a manual transmission. Not sure they use the same kit as the 273 distributors. I have a couple of friends that have had problems getting the stock points cam to work properly with some of their other kits, mainly big block ones with the Pertronix3 kits. Also, if you have a problem with that setup, you can't just re-install the points and condenser to get you home. With the 1383 kit, you can.......and it comes with a cam insert that slips over the stock points cam.
            • 413
              413 Well-Known Member
              438
              508
              Nov 13, 2019
              NW USA
              Local Time:
              7:19 PM
              I’d just get a factory Chrysler electronic Dist and a USA box. Screw that pertronicks stuff.
            • cudamark
              9,274
              1622
              Mar 14, 2009
              San Diego
              Local Time:
              7:19 PM
              Those aren't fool proof either.
              • Agree Agree x 1
              • Bewy
                Bewy Well-Known Member
                1,525
                977
                Jan 1, 2021
                Australia
                Local Time:
                2:19 PM
                For about $40 more, you can buy a brand new Summit dist complete with Mopar type ECU & all necessary parts.
                Using a Pert kit, you would still have an old dist with old cap & rotor, & possibly worn shaft/brgs.
                • Like Like x 1
                • halifaxhops
                  70,765
                  41514
                  Jan 20, 2014
                  Hoppyworld, PA
                  Local Time:
                  10:19 PM
                  Run from the "ls" ones that plastic bushing it rotates on breaks.
                • toolmanmike
                  toolmanmike Moderator Staff Member FABO Gold Member
                  63,513
                  53625
                  Jan 18, 2006
                  Iowa
                  Local Time:
                  9:19 PM
                  • Thanks! Thanks! x 1
                  • cudamark
                    9,274
                    1622
                    Mar 14, 2009
                    San Diego
                    Local Time:
                    7:19 PM
                    Some of us want to keep the stock look. Certainly nobody is advocating using a worn out distributor to start with., although a bit of play in the bushings isn't as critical as it would be with points. New caps and rotors are still available too.
                    • Agree Agree x 1
