picked up a 340 long block w/out specs
Small Block Mopar Engine
  1. JBurch
    JBurch Well-Known Member
    1,697
    817
    Oct 17, 2009
    Owego, NY
    Local Time:
    4:32 PM
    You don't have to pull both heads, pull one and it will tell you what you need to know.......I'll get roasted for this but if it has not gone thru a thermal cycle prior to cracking it open, I'd reuse the head gasket
    • Like Like x 1
    • Agree Agree x 1
    • Garrett Ellison
      Garrett Ellison Amateur driver on public roadway, do not imitate..
      1,275
      871
      Jan 1, 2018
      Southwest VA
      Local Time:
      4:32 PM
      If the head gasket comes off whole without peeling, I wouldn’t have a problem with it. One thing about a blown small block. It really should have a set of head studs. If it was assembled with regular head bolts, I would be weary of the build.
      • Like Like x 1
      • Wyrmrider
        Wyrmrider Well-Known Member
        1,499
        607
        Sep 5, 2016
        los angeles
        Local Time:
        1:32 PM
        What YR said works but use the alcohol not the solvent
        alcohol absorbed water ACE hardware has 99% denatured I use to take heat sinks off cpus
        Then WD-40 that's what WD-40 was made for- it's not really a lube
        • Like Like x 1
        • RustyRatRod
          RustyRatRod 30 Degrees Outta Whack FABO Gold Member
          51,866
          19130
          Jun 7, 2010
          Georgia
          Local Time:
          4:32 PM
          Come on people, we're talking about the price of a gasket set here to see what parts are there and in what condition. I mean seriously, that's the best option.
          • Agree Agree x 3
          • Like Like x 1
          • 72bluNblu
            72bluNblu FABO Gold Member FABO Gold Member
            9,483
            3625
            Nov 28, 2008
            NorCal
            Local Time:
            1:32 PM
            Yeah I don't know why anyone would do anything different in this particular case.
            Like I said earlier, I might do it different if it was advertised as just a stock-ish rebuild and it looked the part. Check some casting numbers, maybe take a peak with a borescope. But in that case I'm assuming its a relatively low compression engine with cast parts and I'm not expecting anything. And even in that case, if I looked in there with a borescope and saw valve reliefs the heads are coming off, because now I know it's not just a stock rebuild with factory replacement stuff.
            For an engine advertised as a supercharged race engine? I'm gonna check everything if I don't know the builder or the parts. Especially before I lay out dough for a supercharger. Even small discrepancies in the build could be catastrophic when the boost starts in.
            • Thanks! Thanks! x 1
            • Agree Agree x 1
            • nixrsix
              nixrsix Member
              7
              11
              Jul 3, 2019
              windward
              Local Time:
              10:32 AM
              Its settled, I shall crack her open!!! I'll post what I fond out this weekend! Thanks for all the great replies!!!
              • Like Like x 1
              • justinp61
                justinp61 Well-Known Member
                1,221
                516
                May 15, 2009
                Local Time:
                3:32 PM
                Smart move IMHO.
                • Agree Agree x 2
