Picking the "right" 383 block? Different styles?
Big Block A body Tech
  1. kythri
    kythri New Member
    4
    0
    Aug 29, 2013
    Lebanon, OR
    Local Time:
    7:52 PM
    Brief background:
    My brother recently picked up a '67 Dart 383 GTS, missing the engine and trans.
    My father just recently recovered his bought-new '71 Duster 340, but the original engine/transmission is long since gone, with a 360 in it's place.
    On either car, it's been decided that finding the original numbers-matched block would be great, but highly unlikely, and it's not going to be something that's going to hold up getting the appropriate model engine in either of them.
    That being said - is there a specific era of block for either of these that we should be looking for? I've been keeping my eye open and trying to help both of them find a suitable engine/trans, and seem to remember reading somewhere that a certain year range was required for both of these - though, for the life of me, I can't find that reference.
    Supposedly, a newer 383 wouldn't fit the Dart, but I don't know if that also held to the Duster and a 340.
    Is this even remotely accurate, or will any 383 or 340 fit their respective cars?
  2. 393foureyedfox
    393foureyedfox Well-Known Member
    71
    3
    Jul 20, 2011
    louisville, ky
    Local Time:
    10:52 PM
    I put a 71 440 from a 71 polara in my 72 duster.
    i imagine any 383 will fit, but I think I do remember something about a machining mod that the factory did to the drivers side engine mount area on 383 cars.
  3. marksmopars
    marksmopars Well-Known Member
    284
    88
    Nov 30, 2011
    Minnesota
    Local Time:
    9:52 PM
    I have heard the same that the engine is mounted from the left front corner, sure someone with real information can assist. I have a 413 out of a 65 300 with the provisions for this mount style, interesting enough the 413 is a 68 date code warranty block! I can take pics of the mount if you need.
  4. rbdart
    rbdart Well-Known Member
    1,925
    19
    Sep 23, 2008
    Golden City Mo
    Local Time:
    9:52 PM
    Most any 383 should work[on gts 383 dart] with the right mounts and drill and tap the 2 bosses on front of block for correct motor mounts,some already have it,also would need to hunt up or buy repro exh manifolds for that paticular engine and yr,am sure there are some other manifolds that will work,same with the 340 they all should interchange no prob with correct mounts and exhausts...there have been some parts and correct items that you are looking for posted here in recent past or place a wanted ad for parts you need and someone will help you out,may have to be a little patient but usually you will find them...
  5. Hyper_pak
    Hyper_pak Old School Chrysler Fan
    1,621
    362
    Feb 14, 2010
    Desoto Texas
    Local Time:
    9:52 PM
    here is what you are looking for. drivers side is the difference. notice rear ear is milled off.
  6. RustyRatRod
    RustyRatRod 30 Degrees Outta Whack FABO Gold Member
    48,128
    13568
    Jun 7, 2010
    Georgia
    Local Time:
    10:52 PM
    You don't need anything special as far as a block for either car. You can get aftermarket mounts to make it happen regardless which block you find. Finding an a body specific 383 block is gonna be difficult, plus when you find it, some idiot will think it's worth its weight in gold. Which it's not.
    • Like Like x 1
    • davescuda
      davescuda FABO Gold Member FABO Gold Member
      8,530
      895
      Apr 30, 2007
      Cheshire, CT
      Local Time:
      10:52 PM
      barracudakid has a 67 A Body 383 engine
    • Rocky_JS
      Rocky_JS 'cuda
      4,212
      147
      Feb 27, 2011
      Happy Valley, Oregon
      Local Time:
      7:52 PM
      67 blocks do not have a vin stamp on them, but the a-body block does have the rear mount ground down also the 2 bolts in the front need to be there, if a P/S car they are there and drilled out already - as pictured above. So for the 67 just look for a block cast 3 to 6 months before the cars scheduled production date, and grind down the left rear mount tab, if you want to be anal about it. Any 383 will work otherwise just keep it easy and find one with the two holes drilled in the front of the block for the left engine mount (pretty common) to find.
      On both engines you want to verify "core shift" or lack there of to define that -search this site- there is a lot of information here on this.
    • Rocky_JS
      Rocky_JS 'cuda
      4,212
      147
      Feb 27, 2011
      Local Time:
      7:52 PM
      The one he has/had was a casting date of - 4-27-67
    • moper
      moper FABO Gold Member FABO Gold Member
      15,412
      1509
      Dec 27, 2004
      eastern CT
      Local Time:
      3:52 AM
      x2.
      All you really need is an earlier block. IIRC '69 and older have the front mount provisions drilled and tapped. The later ones have the bosses but not drilled or tapped. All you need to do is buzz off the rear driver's side ear and once it's painted it will be hard to tell it's not an A body specific block.
    • 393foureyedfox
      71
      3
      Jul 20, 2011
      louisville, ky
      Local Time:
      10:52 PM
      ive seen mid 60's c-body 383's with the front holes tapped already. Those should be cheap and able to be found still.
      I'm not one to care about matching numbers. an incorrect 383 is just as incorrect as a 400, but the 400 is cheaper, easier to find, and able to do more with it when building it.
      btw, i have a whole 400/727 truck setup for sale....first $300 takes the whole thing.
    • no poseur
      no poseur Well-Known Member
      482
      14
      Sep 17, 2013
      Ohio
      Local Time:
      9:52 PM
      This.
    • kythri
      kythri New Member
      4
      0
      Aug 29, 2013
      Lebanon, OR
      Local Time:
      7:52 PM
      Appreciate all of the input from everyone, many thanks! Helps us out quite a bit!
