Pins from the convertible top to the top of the cylinder
hemi446
Ellicott City MD
So I have the interior out of my 67 Barracuda convertible to do a transmission swap and I decide it’s time to fix the power top once and for all. So I got a replacement cylinder to replace the passenger side that failed and a new set of hoses so I pull the side panel out and get ready make the repairs. I pull both cylinders so i can replace the hoses and I see that there are no pins in either side. I must have removed them when the cylinder went bad and now I have no Fing idea were they are plus the bushings in the top of the cylinders are missing to so I spend 3 hours look in my garage and tool box with no luck. So here is my question for all the convertible experts out there. I find two different pins listed a 1 1/8” and an 1 5/8” are listed and when I look down to the mounting holes it looks to be closer to 1 1/8” but before I order the wrong stuff I just wanted see if I can confirm it. This was supposed to be quick and easy to repair and now I have to worry about the panel laying around and getting damaged. So an help you could give would be appreciated Thanks Bobby
You didn't specify top or bottom. Here are the top of the cylinder from my 67 Dart if it helps. (The OD of the plastic bushing is 1.00")
Thanks It is for the top of the cylinder there isn't one on the bottom because the cylinder pivots from the two one the sides. That looks exactly like what I was looking for. Thanks very taking the time. Now I know what I'm looking for. I just can remember where I put them. Thanks Again
