metallidart
member me?
First off, MERRY CHRISTMAS!!
I have a stroker shortblock that I finally decided which direction I want to go with, when I get to it. The rundown--
--1970 340 block, decks cut parallel, alignbored, main studs/girdle, priority main oiling, lifter bores bushed, bored .055/honed with plate. Sonic checked, etc. I bought it used, but got a ton of receipts for machine work.
--Scat forged 4" crank, Eagle H-beams, custom JE Pistons with a slightly higher comp ht than the off the shelf pistons (12.5 with 65cc). Recently freshened, it has been balanced, etc.
--Fluidamper, Moroso pan/pick-up, etc.
Now the question. The odd bore is because the po wanted to keep the cylinders as thick as possible, so he only bored to where he needed to go as he was ordering custom pistons anyway. Well, the compression is too high for what I want to do. I would rather see 10.5 or less with 65 cc chambers. Everything is still nice on the shortblock, I hate tearing it down, but I can't handle the compression that high. So, if I were to tear it down, can pistons that are used be cut/milled, like a slight dish? I would have to make sure they are thick enough on top, that I know. They are flattops, with two valve reliefs. I know I'd have to get new rings/bearings, have it re-balanced, and hone the cylinders. The receipt for these pistons shows almost $800 from JE, I know I won't have that kind of cash for a looong time to come!
Would it be feasible, and cheapest, to have the pistons cut?
Or would it be better to have it taken the additional .005 over and get some off-the-shelf pistons?
I keep trying to come up with what amounts to a "crutch" for the compression, but I think it would be best to just lower it and build it accordingly.
Any ideas?
Any ideas?
