Pitman Arm Stud Rotation Not Smooth
charliec
richmond texas
The stud on my pitman arm doesn't rotate smoothly. Even after greasing it up liberally, it still feels like it clicks or snaps as I rotate it in the socket. It moves to all positions, but not like a ball in a socket as I would expect. Almost feels like it's notched on the inside. Is it shot, or does this not matter?
Can you post a photo of the arm? it's most likely wasted unfortunately.
I'm not sure how much you can see from this short video, but what I'm trying to show is the definite "clicks" at various positions as i try to rotate the stud. I seems that it should be a smooth rotation of a ball in a joint.
On one hand that's not good, on the other a ball joint shouldn't easily spin either. It's done for in my opinon.
