[SOLD] POLY 318 4bbl. Intake Manifold #2206384 & Carter AFB 3249S.
hemi71x
hemi71x
Rancho Cordova, CA
I am putting up for sale this Poly 318, factory cast iron, 4bbl, intake manifold, #2206384, for the Carter 4bbl AFB carburetor.
And selling the Carter AFB carburetor 3249S AM1 that was on this intake manifold.
You will get all the bolts, brackets, coil mount, thermostat housing, temperature switch, heater hose and vacuum fittings, that are on this manifold.
I took all this off a 1957 Plymouth Savoy, and didn't leave anything behind, off the donor car.
As i mentioned i took all this off the 57 Savoy, but the carburetor codes out to be a 1962 Poly 318 Carter 4bbl.
I cleaned the manifold off all the grease and grime off the top side, and bottom side.
Now it's ready for the buyer to paint it whatever color engine paint of your choice.
I will sell the manifold with all the miscellaneous parts as i described in the above sentence at $450.00.
If you wan't to also purchase the Carter AFB, i will sell that separately at $125.00.
I am willing to break up the parts.
The carb is being sold AS IS condition.
It does look in damm good condition.
Give it a try as is, and see if it works, or if not, give it a rebuild.
You have nothing to loose.
Now lets talk about shipping and payment.
This manifold weighs a ton, and is a ball breaker, and hernia getter in lifting it up.
If figure easy 55 pounds, maybe a bit more, packaged up, ready to send.
You will be expecting a hugh shipping quote, so don't fall out of your chair when i look up a quote to your zip code, and tell you what it will be, from me here in California.
I use FEDEX, and send with insurance on the package, and a signature delivery at your end, when the FEDEX driver rings your doorbell.
Now for how i expect to be paid.
For something this expensive i prefer a US postal money order, cashiers check from your bank, or i accept Pay Pal, Family or Friends.
And if an in person, local pick up, cash in hand, hundred dollar bills will do just fine.
Any interested parties, please talk to me thru this forum in a private message, and i will get right back with you.
Thank's a lot.
Jim V.
hemi71x
FYI, Ad Update:
The Carburetor has been SOLD.
Manifold is still For Sale.
"Buyers" haven't been following thru in purchasing it.
Update #2 to this ad.
I now have the air cleaner housing that i removed from the donor vehicle, FOR SALE, when i also got the intake manifold, and the 4bbl. carburetor.
My research on this air filter housing tells me that it was officially used on 4bbl carburetors in the late 1950's, and early 1960's, on TRUCK engines, and not the passenger cars.
So i feel comfortable in telling you that it most likely came off a 1962 engine, back in the day, as that's what the carburetor turned out to be, 1962.
I brought it down to bare metal condition with one of those 3M brand sanding wheels, and then painted it up with Rustoleum black paint.
I'll put this unit up for sale at $100.00.
Interested parties, please send me a message.
Thank's a lot.
Jim V.
hemi71x
Another UPDATE:
The manifold has now also been SOLD.
I will close out this ad.
The Air Cleaner housing is still For Sale.
That hasn't yet been sold.
I will start a separate ad for that.
