RichardR
Hey,
I had a post about fuel pumps, thinking that was my issue, but the pump pumps well. I took the carb off and cleaned it out, rebuilding it with a Walker kit. Put fresh gas in the tank, crank it until the new stuff was in the filter and connected it all back up. Started up great. No issues at all. Was running well.....until engine got hot and it started slowing down. Idle mixture screw did nothing, I actually had to close it almost all the way for it to not die and idle super low. Still uses points.
Any ideas?
Things done:
Cleaned and rebuilt carb
New lines
New filter
Timing checked and adjusted
Valve lashed checked and adjusted
New wires
New plugs
I don't think this is the original carb. Original is in the trunk and is super poor shape. This carb though has a weird jet that can be unscrewed from the outside, located right about where the horn tapers in. Anyone know what that is? I included a picture to show it.
A little more info: it blows a bit of black out of the exhaust when revved
Thanks
Any ideas?
Things done:
New lines
New filter
New wires
New plugs
Thanks
