Pop out gasket
Mopar Body and Trim
  1. KB9GIB
    KB9GIB Well-Known Member
    154
    45
    Jul 25, 2014
    Anna illinois
    Local Time:
    5:40 AM
    Anyone tell me on a 72 Demon pop out glass seal does it set on the body are set inside the quarter panel pitchers would be helpful. Thanks in advance KB9GIB
  2. Oldmanmopar
    Oldmanmopar Going left turning right FABO Gold Member
    8,036
    4039
    Jan 8, 2009
    Danielsville Pa.
    Local Time:
    6:40 AM
    I am not understanding the question. The glass is in it own frame which seals against the quarter to prevent leakage into the quarter panel. Although there is weep holes in the rocker to let water out. One reason they always rust at the lower quarter. I fill the rocker with chassis saver up to the top of the rocker at the quarter and drain it to prevent future rust out after repaired.
  3. KB9GIB
    154
    45
    Jul 25, 2014
    Anna illinois
    Local Time:
    5:40 AM
    Thanks for your reply I was thinking the window seal might lay on top of the quarter panel like newer cars I just could not remember after putting the new quarter panel on. Thanks KB9GIB
