Popping noise after suspension rebuild
Suspension, Steering and Chassis
  1. GSXcite
    GSXcite Well-Known Member
    291
    93
    Oct 11, 2011
    Kansas City, Mo.
    Local Time:
    2:30 AM
    I just finished replacing the upper a arm bushings, lower control arm bushings, upper and lower ball joints and strut rod bushings. After having an alignment done, there is some popping in the suspension at times. I think it is coming from the strut rods. When I reassembled I tightened the lower control arm and strut rod just enough to hold them in place before I loaded the torsion bars, then lowered the car to the ground and torqued them down. I think I may have got them too tight initially and put them in a bind creating the noise. Question, can I loosen the lower control arm and strut rod while the car is on the ground, then torque them back down to see if this corrects the problem. Would it effect the alignment I had done? Thanks
    • Like Like x 1
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      71,820
      47019
      Jun 7, 2010
      Georgia
      Local Time:
      3:30 AM
      Yes. No.
      In that order.
      • Like Like x 3
      • Agree Agree x 1
      • GSXcite
        291
        93
        Oct 11, 2011
        Kansas City, Mo.
        Local Time:
        2:30 AM
        Thank you!
        • Like Like x 1
        • GSXcite
          291
          93
          Oct 11, 2011
          Kansas City, Mo.
          Local Time:
          2:30 AM
          Thanks Rusty, didn't want to ruin a $250 alignment. I thought that was high, but it is hard to find anyone that wants to work on these old mopars.
          • Agree Agree x 3
          • jdsduster
            jdsduster Well-Known Member
            1,199
            191
            Aug 5, 2011
            indiana
            Local Time:
            3:30 AM
            wow that a crazy price.
            • Agree Agree x 2
            • el5dart
              el5dart Well-Known Member
              591
              407
              May 16, 2018
              memphis, tn.
              Local Time:
              2:30 AM
              i just got quoted 70 buck for an alignment from an old school front end shop. appointment on friday.
              did you pack the torsion bars with grease ???
            • GSXcite
              291
              93
              Oct 11, 2011
              Kansas City, Mo.
              Local Time:
              2:30 AM
              He did spend 2 1/2 hours on it, and did some additional things.
            • GSXcite
              291
              93
              Oct 11, 2011
              Kansas City, Mo.
              Local Time:
              2:30 AM
              Yes
            • GSXcite
              291
              93
              Oct 11, 2011
              Kansas City, Mo.
              Local Time:
              2:30 AM
              Have it sorted out. Loosened up the lower control arm and strut rod, moved the car up and down, torqued everything . The nut on the control arm holding the strut rod took more torque than I had it, anyone working great, no noise. Thanks for the help.
              • Like Like x 1
              • 4spdragtop
                4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
                31,536
                12036
                Aug 28, 2009
                Wasting time here
                Local Time:
                2:30 AM
                For our 67 it was $180...stupid prices
              • RustyRatRod
                71,820
                47019
                Jun 7, 2010
                Georgia
                Local Time:
                3:30 AM
                That's just stupid high. You could probably hire one of the NASCAR teams cheaper.
                • Agree Agree x 1
                • 512Stroker
                  512Stroker We are all here because we are not all there.
                  2,342
                  1712
                  May 30, 2016
                  Freedom, MO
                  Local Time:
                  2:30 AM
                  When you talk about "loosened up the lower control arm" are you talking about the nut on the spindle that goes through the K member?
                • GSXcite
                  291
                  93
                  Oct 11, 2011
                  Kansas City, Mo.
                  Local Time:
                  2:30 AM
                  Yes
                  • Thanks! Thanks! x 1
                  • flingdingo
                    flingdingo Well-Known Member
                    332
                    263
                    Apr 26, 2017
                    El Lay
                    Local Time:
                    12:30 AM
                    Whatever triple RRR said, I'll agree with him on principle, but to elaborate...
                    You shouldn't have any noise coming from a properly installed front-end.
                    If you loosen up your control arms a bit and drive the car to eliminate a bind, and then have the alignment re-done, if you keep the mileage under a couple hundred or so, you won't do any lasting damage to the tires or suspension components.
                    Keep in mind that most alignment shops have zero clue what to do with our cars... Never mind the bias-ply vs radials debate... so learning how align your car and investing in the right tools to do so (tape measure, angle finder, etc.) is well worth it.
                  • RabidScott
                    RabidScott Well-Known Member
                    213
                    101
                    Sep 30, 2004
                    Tracy CA
                    Local Time:
                    12:30 AM
                    I don't trust most other people to work on my cars. I just bought my own alignment stuff last week. I have borrowed a buddy's stuff twice before so it was time for me to buy it for myself.
                    Speedway Motors has a good selection, their economy kit was just under $100 and I made my own turn tables. I might upgrade the caster/camber gauge later if the cheap-o one is too janky. smokin.gif
