porpotion valve
3404spdfish
montana
just wondering how I know if my 69 barracuda had SBP disc brakes; because I picked the car up with BBP disc brakes and if it actually cam with drums up front, whats the part number for disc brake proportion valve or how to identify the correct one. also its manual brakes, rats ate build sheet
Sorry I couldn't find a part number for the 69 valve.
Do you have a picture of your current distribution block? If the disc brakes were added a proportioning valve would be added into the rear exit of the block OR the block changed to one with the internal valve.
here is a pic of a manual block
the add on rear valve
then the disk block with the rear valve included.
... if you have sliding front calipers they added a metering block to the front lines.
