6valiant9
Active Member
Hello all, Selling my set of ported 906 steel heads that were done by Nick at Compu-flow years ago. They have big stainless valves and bronze guides, 10° locks, the surface was cut to make cc’s even between both heads, around 87cc I think, (I have the number written down at my shop). They have Isky dual springs 8005A for flat solid camshaft. I had them on a 500” motor with 10.85:1 compression for a few passes before having the distributor gear failed. They need to go to better home. Also to go with heads, a set of Harland Sharp 1.5 rockers set S70015K. Nothing happen to the engine other than distributor gear, took everything apart to make sure. Heads are great. The car wouldn’t make a full pass and ran 11.08....
I’m in CT, 06111
asking $2200 for heads and rockers.... I prefer local pickup or a reasonable drive is also doable. Shipping will be on you.
PM me and I will try to get back to ya’ll in a timely manner......
Thanks
Ross
I’m in CT, 06111
Thanks
Ross
