alsant
Thanks for the info Mattax , well appreciated. Learning curve on my part.
Here, these posts and the links will save you from doing a ton of searching.Thanks for the info Mattax , well appreciated. Learning curve on my part.
www.forabodiesonly.com
The cam in my slant 6 has 250 degrees duration @.050" and it's ground on a 108 LSA. I have it sitting on about 22 degrees initial timing with 10 degrees mechanical and it runs really well. It's also a measured 10.6:1. It also runs better on manifold vacuum to the vacuum advance. But a mild engine will likely not benefit from that.Just stirring the pot: I'm technically running manifold vacuum to my spark control, but I'm faking a ported vacuum advance curve electronically.
Although on a more serious note, an advance curve is an advance curve, an air/fuel ratio is an air/fuel ratio, and the engine doesn't care how you set them. Too much advance gives an unstable idle whether it's from a computer or an advance can. Some full on race cams may benefit from 24 degrees of idle timing, but it's rare for this to be ideal on a milder engine.
Yeah. She's a rowdy girl. lolOk, that cam has 250 degrees at 0.050 instead of 220 degrees? Ok, now I understand why it was so rowdy.
Chrys DID miss the boat on MVA. And the nonsense about EFI not needing a lot of initial timing.....is just that nonsense. The same parameters that make a carbed engine require a certain amount of idle timing....are there with EFI. My Toyota Cressida, an inline 6 EFI engine, idled at 22*. The GM LS engines, high compression [ relatively ], & short duration factory cams, idled with 22* also. As for EFI....
A friend has aftermarket EFI on his 400 cube V8 engine [ I think it is Megasquirt, not 100% sure ], found best idle was with 30* of timing.
As I stated earlier, GM used MVA. My GTO idled at 26* with 10.75 CR & a cam that had 200* @ 050. [ That is 12-14* less duration than the 340/440 Hi -po cams ] .But, but, but...you thought high compression & short duration cams were good with 12* initial idle timing...
Below is the section from the Pontiac workshop manual. Also included are quotes from an English & Australian tuner. See, MVA works worldwide....
Maybe at sea level. lolMVA works worldwide
Those are the guys that tune their automatic transmission cars in neutral or park. lol The same guys using MVA.The claim that every engine needs some absolutely insane amount of initial to get the idle correct is 100% bullshit and it needs to be called that.
Lord hammercy, Bewy. "THIS" thread by "THIS" poster is talking about "THIS" particular build, which has a CARBURETOR and a DISTRIBUTOR. It is not EFI, so your EFI argument is a moot point HERE. Please take it elsewhere, so as not to gum up the OP's thread anymore.So in the Turk world, Turk, EFI doesn't use or need timing at idle? It uses a different 'air' than carbed engines? Perhaps it doesn't even need something like a spark plug to ignite the mixture? You haven't got a clue....
.... Before the thread disappeared, I had provided info & the OP asked where the thread had gone because it contained useful info, some of which came from me. I have also provided many links from a wide range of sources on MVA benefits, in a thread that is about man v ported VA.
I tried. I even asked nicely, but he refuses. So I'm done.@aslant My advice is to ignore the nonsense and/or ask them to take it to their own thread. Worst case start a new thread.
How do you determine what is useful and relevant and what is not?
Well one way is to learn the fundamentals. That will help you seperate what is possible, what is plausible, and what is uh lets be nice and call it a misunderstanding. Whether to use manifold vacuum source or a ported vacuum source depends on the distributor design as well as the engine. When the spark should be fired at idle speed is effected by the timing of when the intake valve closes, the piston dwell time at the top, how much compression is generated at idle, how much heat is in the cylinder, etc. The fact is that Ford used venturi vacuum around 1949. Chrysler used ported vacuum in 1959. Kaiser used manifold vacuum on their Jeep engines in 1963. Chevy used ported vacuum on their high performance engines in in 1965. AMC used a mix of both in the 1980s on their v-8s through a non-linear valve. What does this have to do with anything? Not much other than the following. Some people just refuse to let facts get in the way of their beliefs. The facts discredit the claims made that ported vacuum is a product of poor engineering, are an emissisions reduction method, blah blah blah. The facts can be independently and you should do so.
Another way to decide what is relevant is observe whether the person has any real first hand knowledge or experience, or is just repeating things he or she has been told and beleives. For me, once someone has been exposed as a BS artist, they are forever discredited as a reliable source of guidance. Sometimes these are well meaning people, but as I wrote over at Speed-talk, they don't recognize the limitations of their knowledge. Knowing enough to be dangerous as we say. LOL. It doesn't matter if you were an engineer or a magazine writer.
Hi Mattax.Maybe that's best.
Post a new thread when you have all the specific info for your engine, including the curent timing from idle to as high as you care to measure.
Let this thread drift off into oblivion....
Some day I'll get around to fighting with paypal and renewing my membership.Hi Mattax.
Tried to write you about an alternator issue, but your inbox is full. Just FYI
