Position of Tie Rod Ends
Discussion in 'Suspension, Steering and Chassis' started by charliec, Nov 4, 2018.
  1. charliec
    charliec FABO Gold Member FABO Gold Member
    134
    79
    Jun 13, 2017
    richmond texas
    Local Time:
    8:20 AM
    I know that the tie rod ends are threaded differently (LHT and RHT) so the adjusting link will work. Does it matter which one is installed on the outboard end of the linkage and which one is on the inboard end?
  2. 72Dart6pack
    72Dart6pack Harder Better Faster Stronger.
    2,695
    1731
    Feb 1, 2016
    Roseville Michigan
    Local Time:
    9:20 AM
    The clockwise tie rod end goes on the outside.
    • Thanks! Thanks! x 1
    • Murray
      Murray FABO Gold Member FABO Gold Member
      775
      365
      Apr 19, 2010
      San Jose, California
      Local Time:
      6:20 AM
      Doesn't matter.
    • 72Dart6pack
      2,695
      1731
      Feb 1, 2016
      Roseville Michigan
      Local Time:
      9:20 AM
      No it doesn't matter. From the factory they came right hand thread was the outer.
    • dartfreak75
      dartfreak75 Well-Known Member
      2,141
      955
      Aug 10, 2011
      Virginia
      Local Time:
      9:20 AM
      Good info guys thanks this is a question I had too and havent asked yet. I guess the only reason I could see it would matter would be for the the alignment guy if he turns it one way to take it one way but it goes the other way he may get confused lol.
    • charliec
      134
      79
      Jun 13, 2017
      richmond texas
      Local Time:
      8:20 AM
      Many thanks for help.
    • 67Dart273
      67Dart273 Well-Known Member
      38,310
      5892
      Oct 14, 2010
      Idaho
      View My Photos
      Local Time:
      6:20 AM
      Actually "it did" matter.........back then..........to the front end guys who knew LOL
      Once I replaced all 4 ends on my RR and took it to an alignment guy. Hell I didn't know any better. Anyhow, he told me "somebody" had the tie rods reversed LOL
      At least try to get both sides the same
      It also (at least to) used to matter when you BOUGHT them. You could go to the parts store and buy "inner" or "outer." We used to HATE it when people opened the boxes and mixed them all up!!!
