mopar_nocar
Picked up a 1987 D150. Drove it home and checked the rear axle gear oil level -- could not even touch it. Put a qt in to get it level with the fill hole. Truck would "clang" when put into reverse or from reverse to drive. Then on the way to work, took a left and it acted like it had a spool in the rear end.
Parked it and finally got a chance to pull it down...here are the gears. I fished several pieces out of the housing as well.
What the heck caused this? This is not a hotrod, just a 318/904 2bbl truck with 2.94 gears. Would love to avoid a repeat performance...incidentally, I grabbed a complete axle out an 89 Ramcharger with 3.55s at the JY and the truck is MUCH better for it...going to clean up the original axle and put in 3.90s or 4.10s for the eventual OD trans swap.
sb
sb
