BillGrissom
This e-bay "suggestion" popped up after a recent purchase. Caught my eye since the size sounds close. I know nothing of the seller. There are probably other ones out there. I have read many people trying hard to find an aluminum radiator for earlier A's.
http://cgi.ebay.com/ws/eBayISAPI.dl...4012.m656&_trkparms=clkid=5007930228308677809
If overall dimensions are OK, looks like the tube locations would work on SB's with the cast iron water pump (pre ~1970). Not for me since I converted to the aluminum water pump (don't recommend).
Looks like no fill neck, but I recall there are in-hose ones. The factory compressor would probably conflict, but not most after-market compressors. My upper tube is in the same place and I used the upper hose for my 65 Newport. You would have to make brackets. Don't blame me if you try and doesn't work. Just trying to help.
