slapstickjim
I bought this 76 dart this winter. I been going overr it now that's it's nice been driving it. Looking it over( wiring) I saw nothing crazy. Like cut ,spliced wires etc. I installed a volt gauge and noticed it was a tad over 14,. As my old eyes from 3 ft saw without readers lol. I drove it the other night and headlights were going dim bright dim bright. So I check at battery and I am getting 15.6 volts.
Should I be concerned???
I looked over things a few hours and tried stuff after each trial I would start car and still 15.7. What I did. Used regulator, new regulator, ground wire from regulator mounting to batery, ground wire engine to body installed, new starter relay, unhooked rehooked alt wires, jumper cable battery to body, bulk head connectors from engine side unhooked no corrosion and cleaned with brush and hooked back up. No wires seem cut frayed damaged.
If a concern what else under hook to check??
Next is to check under dash. Idk steering column grounded? Ignition switch bad?
Can I unplug column and hot wire ignition to start car to see if that drop voltage?
Thank for advice. Jim
