slapstickjim
But i do want to double check headlight circuit. I put new headlights in and some of the wiring I did fix so maybe I missed something. But when did key bypass all voltage seemed corrected
His alternator is producing power at 15.4 V.One thing that kind of stood out to me is that you noticed that the lights were going from dim to bright back and forth. Does any other light, say the dome light, do the same thing? Or is it just the headlights? I would check the harness behind the grill and see if there are any grounds to frame on the light circuit. Those radiator support frames can get pretty rusted out if it hasn't been worked/replaced.
You also might be able to isolate the circuit in question by bridging the fuses with a voltage meter/amp gauge or a test light, and see if that points to anything.
So all reading im getting should suggest wiring good in engine bay?His alternator is producing power at 15.4 V.
That's the number one problem.
His bypass still used the body and chassis grounds, so they are OK.
Therefore the main problem is between the bulkhead connections for J1 and J2.
The bulkhead connector itself, the steering column connectors (theirs two) and the key switch are the most vulnerable locations.
It's pretty easy to narrow down checking for voltage drop along the current path.
It could also be multiple locations of resistance that add up.
I don't know. Maybe it's something as simple as a bad battery. It could be a source of resistance causing the VR to react. It's just hard to troubleshoot where I sit. It's a lot easier being there. I can offer suggestions but it's the nature of electrical. Process of elimination. I wish I could be of more help here.His alternator is producing power at 15.4 V.
I have my grill out. Come stop overI don't know. Maybe it's something as simple as a bad battery. It could be a source of resistance causing the VR to react. It's just hard to troubleshoot where I sit. It's a lot easier being there. I can offer suggestions but it's the nature of electrical. Process of elimination. I wish I could be of more help here.
Explain that.Maybe it's something as simple as a bad battery. It could be a source of resistance causing the VR to react.
It's like an internal "short" in a battery. Where the battery trips the VR to charge where it's needed or not. It doesn't happen very often. I'm throwing out possibilities of things that can happen. Sometimes the simple and obvious gets overlooked.Explain that
Sorry I still don't get it.It's like an internal "short" in a battery. Where the battery trips the VR to charge where it's needed or not.
It usually happens on an old battery. Specially one that's not a "maintenance free" battery. Water is sometimes added, if it's not distilled water (usually not) it can introduce stuff like minerals and things that can bridge across plates inside of the battery. The cell just doesn't have to "fail" completely to be a problem. It's a battery. Just like anything: If it's made by human hands, anything can fail.Sorry I still don't get it.
If a battery is shorting its going down a cell and won't charge properly. Don't see how that the regulater.
It does not have to be a process of elimination.
Stuff like this is straight forward diagnostic following the current flow.
As far as taking the battery out of the circuit, that's a shade tree method that was all too common.
Disconnect the battery and if the engine keeps running they know the alternator is working.
There's a number of problems with doing this but it often works. It can cause spikes that can damage transistors. But people who do it don't really know much about what they are doing. As often it doesn't work and they think its the alternator failing.
In this case Jim's experiment where he bypassed the interior wiring showed the battery has nothing to do with the high voltage.
His measurements show there is resistance in the path between the Bat terminal and the Field terminal.
Put the two together and the problem is between the bulkhead connection for J1 and J2. A few more measurements and he'll know more precisely. Hate to see anyone unwrapping wires and replacing parts that are fine. He got about halfway there but took some sidetracks. I'm trying to help him understand how track it down so he's not taking any more sidetracks.
Potato potato I like both. And batery was on my list but after i hotwired and voltage was fixed. No need and I was looking at ground and lights. But again voltage fixed at hotwire. So to me everything says bulkhead in. ButOk. You know best. I've been working on vehicles since the 80's, but hey, I might need a few more years before I get it. I'll just drop back on this post and let you handle it. You seem to know what's going on. Just ignore what I said. I am a potato.
I was very careful and meticulous back in Feb under my dash. Dash wiring should be not the issue. I'm thinking ignition which is in said circuit.
Wait you say halfway. Uggg another 7 hours to go baha
I'm sorry I missed that. Maybe ther terminal not quite fitting effected the connector s othe J2 wasn't tight.Looks like my plugs except there was one more all coming out of steering column. That top plug q12 bk was one that was not completely in. When messing with it it was shutting heater fan and radio off when I pulled just black wire out. I cleaned it and pushed it in and I clicked and seems tight now.
The '76 wiring strategy should minimize resistances so not too surprised.I installed after market gauges and volts show hair under 15. And tested it all over seems 14.7 ish all over. Even had headlights on, door open, radio on, heater fan on and wipers. Seemed to hold 14.7ish all over.
You eliminated the resistance.Not sure what I did to fix it but no complaints.
In most cases I would say stop worrying. Most of this is chicken little, and some percent is real but self inflicted. I can post you some links (no pun intended) a bit later.So, what if anything do I need to do to make the bulkhead connection safe and not have to worry about fires.
But I had steering column completely unhooked and domelight was dimingThe voltage regulator needs a clean non fluctuating voltage on the blue ignition wire. You might have dirty contacts in the ignition switch. Ive seen this cause issues like the flickering headlight syndrome. I use a relay to supply the power to the voltage regulator ignition wire. This might cure your problem.
