Post Mortem on a 360
Small Block Mopar Engine
  1. yellow rose
    yellow rose Doctor of Thinkology.
    16,600
    12933
    Jun 19, 2015
    Living on the razors edge
    Local Time:
    3:24 PM
    I'd sleeve that block in a New York second and never look back. Done correctly, the sleeve will be as strong as the original block, and the materiel of the sleeve will be better if you get the right sleeve.
    Secondly, if the pickup turned in the pump, it wasn't set up correctly. There is no way the pickup can turn if the pickup is touching the bottom of the pan, and it should be touching the bottom of the pan.
    Seems silly to throw away a block. Any block you end up with will need to be decked, line honed and everything else.
    • Like Like x 1
    • MOPAROFFICIAL
      MOPAROFFICIAL Well-Known Member
      3,376
      2350
      Jun 1, 2016
      breakwater
      Local Time:
      3:24 PM
      If you look back in some of the pics you kind of see the pick up Mark at the bottom of the pan, that's how I figured it was there where it needed to be. I agree he could sleeve it. Me? I'd rather start with a fresh block for something high-output. I agree on the durability etc of a sleeve, but I've also had a sleeve installed by a reputable shop move .010 down after so many runs down the strip @ 400hp 9.5 comp. Its inside the fire ring.. wouldnt have known it if I didn't pull n go through the x heads...but still, it wasn't done right is all.. but it ending happening..like anything can. Before all else ...I'd be sure of what exactly happened and correct it. No brainer, I know..
      • Like Like x 1
      • Dartnut
        Dartnut Don't hate me because i'm beautiful
        9,991
        1966
        Apr 19, 2007
        Southern Alberta
        Local Time:
        4:24 PM
        You hit the nail on the head here.
        Just so everyone knows, i knew the guy that built the car some years ago and that's exactly how he did things as you described it.
        Nothing special such as decking or balancing went into this engine.
        He built hand grenades and poured the laughing gas to 'em hoping that they would hold together................lol
        • Like Like x 2
        • Wyrmrider
          Wyrmrider Well-Known Member
          1,362
          520
          Sep 5, 2016
          los angeles
          Local Time:
          3:24 PM
          we used to take a stock junkkyard hemi, add our heads, cam and carbs and run jr fuel
          back when dragracing was fun
        • Krooser
          Krooser Reform School Graduate
          1,228
          881
          Jul 19, 2015
          Land of Cheese
          Local Time:
          5:24 PM
          In '79 during my first visit to Bonneville I wound up helping some fuel altered guys rebuild their motor in their motel room... even had the legendary bath tub parts washer going...
          Jim you've heard the stories of these guys buying Hemi's at the junkyard in SLC, then doing what you did with heads and such, then running 200 mph+ the next day. No time for nothing fancy when you have records to run for....
          • Like Like x 1
