Post pictures of ur race car here!
Here is my Junk. Currently a 15 second 318 car but my Magnum 360 build will go in within a few weeks. Hoping to be in the low 12s after the swap.
Snafued this thread from the start. I oughta give you an infraction for the hell of it.lol
I should have some pics of the Scamp at the track in the near future, hopefully that will make up for it. If it matters though, the Stang does mid 10's at 3955 lbs race weight. Not bad for a daily driver/race car.
Tony nice shots badass smallblock racers .outlaw dart mean *** swinger .....
Heres some older ones of mine as its not 100% ready to hit the track again.
Wheelsup, awesome car. Question, how do you keep from killing the front suspension, oil pan , headders, etc when you pull the wheels that high?
I have done a number of things. After the very first bumper dragging wheelstand that hit the oil pan when it came down I went from a 26 inch front tire to a 28 in front tire. I raised the frontend up about 1 1/2 inches and installed poly 2 inch bump stop on the lower control arms to keep from bottoming out. I completely went through the front end with tube upper arms with heim joints, boxed in the lower arms and used nylon bushings on the lower arms with Firm Feel greasable pins. I installed 11/16 tie rods from a b body and bought the soild adjusting sleeves from PST. I bought a set of adjustable strut rods also from RMS. have not had any problems since and that was about 4 years ago or 500 plus wheelstands. Here is a vid of the frontend. Its alittle dark til the go pedal gets smashed to the floor , pause it at 38 sec and you can get a look at the frontend.[ame]http://youtu.be/ux4dEsgBY7E[/ame]
Here is my 10 sec dart. the motors out for new heads and installing new front end(Hemi Denny).
This dart is badass! Are those the weld RTS wheels? Have any more pics you can post?
