1. olddman
    olddman Well-Known Member
    219
    56
    Oct 11, 2006
    Cypress, Texas
    Local Time:
    10:57 AM
    Thinking of having wheels powder coated. Has anyone had this done? General thoughts on doing this, pros and cons.
  2. Syleng1
    Syleng1 Karma is real and Life is short... FABO Gold Member
    2,412
    2094
    Jul 5, 2005
    North Franklin, CT
    Local Time:
    10:57 AM
    Powder coating is great. But here in the NE a simple scratch and the salt and sand get in and don’t leave. JMHO.
  3. 8formulas
    8formulas Well-Known Member
    151
    64
    Oct 5, 2015
    Connecticut
    Local Time:
    10:57 AM
    I had it done to the wheels on my Super Bee. It was pricey but WELL WORTH IT.
  4. harrisonm
    harrisonm Well-Known Member
    3,823
    4284
    Jan 16, 2005
    Topeka, KS
    Local Time:
    3:57 PM
    It is worth it. Powder will hold up way better than most paint. I have powder coated a lot of wheels. I HIGHLY recommend clear coating all wheels for protection. I use a very nice high gloss clear powder. You should contact @CudaChick1968 and ask her to do your wheels. She does amazing work.
    It is fairly pricey because wheels are a pain. For their size, they take a while to do. I will do wheels, but they are a pain, and I charge accordingly.
    • Thanks! Thanks! x 1
    • A56
      A56 MoPar Affliction
      5,783
      15675
      Jun 24, 2014
      White Oak, N.C.
      Local Time:
      9:57 AM
      Powder coating is great if it's done properly and the coating is the correct thickness. After spending the money it's real important that whoever mounts your tires doesn't gouge the rims. I would consult with @CudaChick1968 before proceeding with the powder coating.
      • Like Like x 1
      • j_anderson
        j_anderson Well-Known Member
        226
        97
        Aug 15, 2019
        NE Indiana
        Local Time:
        10:57 AM
        I would advise against powder coating wheels. The problem is if you get chips or a scratch, the only way to fix it is to strip the wheel and re-powdercoat it. With paint, you can touch it up. Just my $.02
        I had a set of summer wheels refinished in Black Chrome which is powder coat then PVD coat of black chrome for my Cadillac. When the dealership service guy rotated my wheels (without my knowledge), he used an impact to remove lugs and chipped the holy hell out of each lug pocket. The only fix was to strip and recoat all the wheels.
        • Agree Agree x 1
        • Dana67Dart
          Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
          8,230
          5768
          Jul 16, 2017
          Northern Colorado
          Local Time:
          8:57 AM
          I too have had bad results with powder coated wheels.
          1. They coated the inner index hole, i had to sand the crap out of it to get the wheels on.
          2. The back mating surface of the wheel that mates to the hub needs to be flat. I had to sand that too to get down to metal
          3. Sams Club did not protect the wheel or put the center cone on backwards when they balanced the new tires (Wheels only had 1 year of use) and all 4 wheels came away with gouges.
          4. The lug nut hols are all chipped up
          5. And there is an odd wrinkling on some of the centers.
          I say paint. As noted by j_anderson, much easier to repair
          And yes they were done by a profesional shop, and sandblasted first.
        • Jeff Seighman
          Jeff Seighman not my real name
          642
          1148
          Jan 19, 2020
          South Carolina
          Local Time:
          10:57 AM
          Did Sams Club do all that damage to your wheels? It looks like dents, not just nicks in the powder coat
          Jeff
        • A56
          5,783
          15675
          Jun 24, 2014
          White Oak, N.C.
          Local Time:
          9:57 AM
          Sorry, but there is nothing professional about that job.
          • Agree Agree x 1
          • cudamark
            cudamark FABO Gold Member FABO Gold Member
            9,249
            1609
            Mar 14, 2009
            San Diego
            Local Time:
            7:57 AM
            I had my stock steel wheels powder coated and they came out wonderful.
          • Dana67Dart
            8,230
            5768
            Jul 16, 2017
            Northern Colorado
            Local Time:
            8:57 AM
            They did the circular markes on each raised lug spot.
            I got an insurance claim paid by them. They looked at the wheels and could not argue their way out if it. The chips have happened over the years (10 years???) The wrinkling is more recent like 5 years, it is solid underneath.
            • Like Like x 1
            • harrisonm
              3,823
              4284
              Jan 16, 2005
              Topeka, KS
              Local Time:
              3:57 PM
              Well, in my opinion, you guys can say what you want, but a good job of powder coating is going to be better than a good coat of paint, unless you assume that paint holds up betted than powder coating. All of the damage I see in the pictures above would have also happened with paint. The over zealous tire technicians who did that damage would have damaged paint just as badly. Another thing is the comments about touching up nicks and chips. To say that a few nicks and chips will require the entire wheel to be stripped and re powder coated is hog wash. Are you also saying that if a painted wheel gets a few chips in it, the only remedy is to strip it down completely and repaint it? You can easily touch up a nick in a powder coated wheel. I do it all the time. I can always find a paint close enough to do a nearly invisible touch up. That is like saying that if you get a few chips on the fender or door of your car, you need to repaint that entire panel. I have powder coated hundreds of wheels over the years, and I will tell you that powder will stand up better than most paints, and that chips can easily and effectively be touched up. PS @olddman your PM box is full.
              • Like Like x 1
              • Agree Agree x 1
              • mopowers
                mopowers Well-Known Member
                6,193
                3422
                Feb 15, 2006
                West Sacramento, CA
                Local Time:
                7:57 AM
                What's it cost to powder-coat a set of wheels? Assume new steel wheels from say, Wheel Vintiques.
              • harrisonm
                3,823
                4284
                Jan 16, 2005
                Topeka, KS
                Local Time:
                3:57 PM
                I can't speak for others, but I usually charge about $100 per wheel on a new wheel. They still have to be sand blasted to get the current paint off them. But I am retired, and it is just a hobby that allows me to earn a little money. If it was my living, I'd probably charge more. But I have all the business I want here in Topeka by word of mouth. I would never suggest or ask for anybody to mail me parts to coat. If I got to the point where I was powder coating 30-40 hours a week, it would be too much like work.
                • Like Like x 1
                • 8formulas
                  151
                  64
                  Oct 5, 2015
                  Connecticut
                  Local Time:
                  10:57 AM
                  I wish I only paid $100 per wheel. That's cheap.
                  • Agree Agree x 1
                  • 72Dart6pack
                    72Dart6pack Harder Better Faster Stronger.
                    4,811
                    5371
                    Feb 1, 2016
                    Roseville Michigan
                    Local Time:
                    10:57 AM
                    Outside silver. Inside Black. Pay attention. That's how they came out of the factory
                  • A56
                    5,783
                    15675
                    Jun 24, 2014
                    White Oak, N.C.
                    Local Time:
                    9:57 AM
                  • 72Dart6pack
                    4,811
                    5371
                    Feb 1, 2016
                    Roseville Michigan
                    Local Time:
                    10:57 AM
                    Blasted & Powder coated. Cost $120
                    • Like Like x 1
                    • Alaskan_TA
                      Alaskan_TA Well-Known Member
                      6,259
                      4918
                      Nov 12, 2004
                      PA
                      Local Time:
                      10:57 AM
                      Powder coating chips.
                      It chips when the lug nuts are tightened, from rocks, hub cab / wheel cover removal etc.
                      As it chips under the lug nut mating surface, your torque settings change too. (no one wants lug nuts to come loose when driving)
                      Paint will get flaws too, but paint is easy to redo at home.
                      Powder coating has its place at times but for wheels, it sucks.
                    • Ironracer
                      Ironracer Gearhead
                      3,176
                      2310
                      May 8, 2020
                      Tampa Bay Florida
                      Local Time:
                      10:57 AM
                      That's sucks! Did they repair em?
                    • Ironracer
                      Ironracer Gearhead
                      3,176
                      2310
                      May 8, 2020
                      Tampa Bay Florida
                      Local Time:
                      10:57 AM
                      Shoot Man, that's a smoking deal..
                      • Agree Agree x 1
                      • j_anderson
                        226
                        97
                        Aug 15, 2019
                        NE Indiana
                        Local Time:
                        10:57 AM
                        They did. However, I chose to have them painted the second time around
                        • Like Like x 1
                        • rumblefish360
                          rumblefish360 I have escaped the evil Empire State! FABO Gold Member
                          42,220
                          14391
                          Jun 21, 2005
                          Florida
                          Local Time:
                          10:57 AM
                          • Agree Agree x 1
                          • Ironracer
                            Ironracer Gearhead
                            3,176
                            2310
                            May 8, 2020
                            Tampa Bay Florida
                            Local Time:
                            10:57 AM
                            • CudaChick1968
                              CudaChick1968 Leanna ~ The Mistress of Metal FABO Vendor
                              10,856
                              5597
                              Jan 17, 2005
                              Greenfield, Tennessee
                              Local Time:
                              9:57 AM
                              Thank you! I typically avoid coating used aluminum wheels like The Plague -- people love their Armor All and tire wet products too much; being silicone based, the stuff leaches into the metal and only a caustic, EPA-controlled chemical called B17 will remove it. B17 will also eat the concrete in my shop if it spills so I don't use it.
                              Steel wheels are a different animal altogether and $100-200 apiece is about standard.
