Power and ground
Electrical and Ignition
  1. Evan Dutch
    Evan Dutch Well-Known Member
    506
    83
    May 11, 2016
    monroe north carolina
    Local Time:
    4:26 PM
    What do you guys do when running electric accessories; fans, aftermarket ignition, etc. but you don’t want to run all your power and ground wires directly to the battery terminals that way there aren’t tons of wires on the terminals.
    Is there a panel I can run battery power to and then run all my accessory to that Panel that way it’s neat?
    Thanks
  2. TrailBeast
    TrailBeast Slightly Twisted Member
    19,223
    5564
    Mar 11, 2011
    Arizona
    Local Time:
    2:26 PM
    They are called power panels.
    I ran a 10ga wire off my starter solenoid to a breaker with studs and nuts on it, then run accessories off that.
    Here's a Google search for 12 volt power panel. 12 volt power distribution panel - Google Search
  3. Willyrd
    Willyrd Well-Known Member
    150
    67
    Apr 16, 2018
    Southwest Ohio
    Local Time:
    4:26 PM
    You could do a battery to body ground so you can just do chassis grounds
  4. Evan Dutch
    506
    83
    May 11, 2016
    Local Time:
    4:26 PM
    Ah, so it’s similar to a bus bar?
  5. toolmanmike
    toolmanmike FABO Staff Staff Member FABO Gold Member
    35,217
    17194
    Jan 18, 2006
    Iowa
    Local Time:
    3:26 PM
    Only Buss bars are for grounds and don't have fuses.
  6. Evan Dutch
    506
    83
    May 11, 2016
    Local Time:
    4:26 PM
    So I could pull power for the accessories from the power panel and then ground them all to a common buss bar.
  7. toolmanmike
    35,217
    17194
    Jan 18, 2006
    Iowa
    Local Time:
    3:26 PM
    If you choose. Cars have used chassis grounds for years. The battery negative is grounded to the block and usually the radiator support. The block is grounded to the body at the firewall. Everything that is metal that is attached to metal is automatically grounded. You can run 2 wires and ground one if you wish.
  8. Evan Dutch
    506
    83
    May 11, 2016
    Local Time:
    4:26 PM
    Thanks
  9. 67Dart273
    67Dart273 Well-Known Member
    38,641
    6247
    Oct 14, 2010
    Idaho
    Local Time:
    1:26 PM
    The problem with chassis/ body grounding is "now." "Now" we have lots of sensitive electronics, and you can get into "ground loops" which can cause interesting problems. Unfortunately, tho, many of the electronics themselves are not properly set up to deal with this.......stereo/ cb/ radio equipment, etc.
    A "single point ground" like "think (wood, glass) boats" where you have NO ground, just a positive and negative terminal
    If you have a fairly conventional "simple" car with just lights, ignition, etc, you are pretty safe. You get into EFI, data loggers, and other electronics, it gets more difficult
    MSD has/ did have an article on interference. It is possible for example, for the spark produced by an MSD to re-trigger it's own unit, creating false spark timing. This high powered spark can affect other "stuff" like the voltage regulator!!!
  10. Evan Dutch
    506
    83
    May 11, 2016
    Local Time:
    4:26 PM
    I’m running a msd 6al box, what’s the best way to ground it? Instructions say right to the battery.
  11. 67Dart273
    38,641
    6247
    Oct 14, 2010
    Idaho
    Local Time:
    1:26 PM
    That. and run your trigger wires close to a "ground plane" that is along the block and firewall, try to cross plug wires at right angles to the trigger, and keep them away
