Power brake conversion issue
Early A-Body Discussions
  1. cudafish65
    cudafish65 Well-Known Member
    77
    12
    Jul 27, 2016
    long island NY
    Local Time:
    4:56 AM
    Converted my 65 barracuda to a dual master power brake system. 4 wheel drum. After about a 10 minute drive, all 4 brakes will lock up. I can relieve the pressure at the master and it will be fine for a little bit. I think I have a faulty master cylinder, has anyone experienced anything like this?
  2. SIX225
    SIX225 Well-Known Member
    144
    71
    Jan 31, 2016
    Illinois
    Local Time:
    3:56 AM
    I believe that on a power brake setup that the push rod into the master cylinder is adjustable. If not adjusted right, I believe that it will cause problems like you have described. Searching for push rod adjustment should bring up a few be threads on adjusting it (sorry, can't find the ones I had bookmarked). Had a similar problem on my manual brake set up, but for different reasons.
  3. Killer6
    Killer6 Well-Known Member
    2,544
    865
    Mar 9, 2015
    PA
    Local Time:
    3:56 AM
    I wouldn't assume it is the master cyl., it works fine cold for how long? As SIX225 stated, pull the MC loose from the booster and look at the pushrod, if it's adjustable that is one
    option. Does the pedal get really firm when this occurs? Also check the strut link between the pedal & booster, is there a small amount of play, did it go on easy or....?
    Also I assume You left enough air-space in the reservoir for the fluid to expand
    w/the underhood heat etc. Unless all 4 sets of shoes are adjusted too tight,(not
    common but possible), fluid expansion is the only other temp/time related item.
  4. RedFish
    RedFish Well-Known Member
    25,018
    3367
    Sep 5, 2007
    Local Time:
    3:56 AM
    You didn't provide much info, what parts used, etc...
    Fluid lines on engine side of master or fender side of master?
    Exhaust heating brake fluid has been a issue for others.
  5. cudafish65
    77
    12
    Jul 27, 2016
    long island NY
    Local Time:
    4:56 AM
    Well the push rod is not adjustable, the lines run along the fender down to the stock location with a new distributor block. the pedal does get real firm when this happens. if there was too much fluid lets say, wouldn't it leak out the master? if there was that much fluid I feel I would have some sort of leak
  6. RedFish
    25,018
    3367
    Sep 5, 2007
    Local Time:
    3:56 AM
    The small push rod at front of booster going to master cylinder is not adjustable ?
  7. SIX225
    144
    71
    Jan 31, 2016
    Illinois
    Local Time:
    3:56 AM
    Did you replace the MC? I ask because the power brake ones should have a retaining ring where as the manual ones have a plate with a dust boot on it and an undercut to retain the push rod. My car is a manual brake car where the plate was no longer flat and someone left the remnants of of the piston seals on the shaft . This prevented the piston from returning properly and resulted in locked brakes after driving for a few miles because the compensation ports were blocked.
    • Agree Agree x 1
    • dirty white boy
      dirty white boy 50 yr old Juvenal delinquent
      1,497
      864
      Dec 15, 2012
      stoneville n.c.
      Local Time:
      3:56 AM
      sounds like a rubber line coming apart in side and restricting flow back to MC.
    • cudafish65
      77
      12
      Jul 27, 2016
      long island NY
      Local Time:
      4:56 AM
      yea I replaced both the booster and MC as an aftermarket kit
    • cudafish65
      77
      12
      Jul 27, 2016
      long island NY
      Local Time:
      4:56 AM
      I was thinking that originally but the brakes were working fine before I did the conversion, so I look at the last thing I did when theres an issue
    • SIX225
      144
      71
      Jan 31, 2016
      Illinois
      Local Time:
      3:56 AM
      Since cracking the lines open relieved the pressure, my research when I had my problem lead me to the blocked compensation port issue. Someone above mentioned loosening the master from the booster. Did you try that yet? That would allow the piston to travel back if the rod holding the piston in. Since the rod is not adjustable, maybe test it by shimming out the master from the booster with some washers.
      • Agree Agree x 2
      • Like Like x 1
      • AJ/FormS
        AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
        20,970
        8302
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        3:56 AM
        That is very definitely a non functioning compensating port. To prove it release the fluid pressure by cracking a line. Very carefully measure the fluid level in the reservoir. Clean the rubber lid seal, the side that faces the fluid.Put the lid back on.
        Now, go pump the pedal until it gets hard and high and no longer accepts pumping action.
        Next go remove the lid. Look at the the seal you wiped dry. There should be fluid all over it from the returning fluid spray. Is it dripping? Next measure the fluid level. It should be exactly as you marked it. Is it? Put the lid back on and secure it.
        Two no's means the fluid is trapped out there.
        Let's get it to come back.
        Oh, I see SIX225 already gots you covered!
        • Like Like x 1
        • Thanks! Thanks! x 1
        • RedFish
          25,018
          3367
          Sep 5, 2007
          Local Time:
          3:56 AM
          I recall a 88 T-bird that would begin each day just fine then keep enough residual brake pressure to cause hot lining odor. The lady had the lining replaced a few times in a short period, front calipers replaced once also. Her son ( one of the salesmen where I worked ) said he thought she drove with 2 feet, riding the brakes. When it came through the door I couldn't turn a front wheel by hand. The next morning I could. I did suspect the booster but found the master cylinder was the fault. The spool valve/piston/whatever you wish to call it would stop just short of fully returned, as if the spring inside was weak.
          The front wheel drive Cutlass Ciera that would lock up only 1 rear wheel is still the most notable oddball case in my memory. That was a pre antilock master cylinder proportion combo assembly.
          I don't know that the T-bird came off the assembly line with a flaw. It had been in a fender bender.
          I feel certain the lil Cutlass had its brake system flaw from day 1. Not all brand new parts are good parts. Good luck with yours.
        • BillGrissom
          BillGrissom Well-Known Member
          7,542
          469
          May 10, 2009
          Sacramento
          Local Time:
          1:56 AM
          Did you remove the brake lamp switch first? If not, the pedal may be bottoming out on it so the MC piston doesn't fully retract. If so, the fill ports may not get exposed. If correct, the tubes should be open to the reservoir with the pedal off, thus no pressure build-up possible. If not, you will not only lock-up pressure in the tubes, they will not refill so if even a tiny leak the pedal will keep dropping until you have no more brakes. Amazing how many people here don't understand the brake lamp switch and how to adjust it. It should not affect the pedal, only sense it.
          Most Mopar factory power boosters have an adjustable output tip, as I recall. I would expect an after-market would be even more likely to have one. Unbolt the MC from the booster and look again. Same deal if it is too long, you will stop the MC piston from fully retracting. Adjust until you have just a slight amount of play, just like adjusting the brake cable on a road bike.
          • Agree Agree x 1
          • 73hcode
            73hcode Well-Known Member
            1,005
            371
            Apr 3, 2011
            Long Beach, Mississippi
            Local Time:
            3:56 AM
            I had a Toyota truck do the same thing. I changed the m/c but that didn't help I sold the truck because it had over 300 thousand miles but often wondered about that problem. The only thing I could ever figure out is maybe where the vacume hose was attached the supposed to be vacume was positive pressure and it would pressurize the brake system. My pedal was rock hard. I might be way off base but it is all I could think about.
          • cudafish65
            77
            12
            Jul 27, 2016
            long island NY
            Local Time:
            4:56 AM
            been busy last few days. finally got back to looking at it. as I was pulling the M/C off I noticed the car starting to move. I temporarily put washers in between master and booster and drove the car a bit. brakes worked perfectly. now for some reason my push rod is non adjustable so I had to shave it down a bit. now all works perfectly. thanks for all the responses
            • Like Like x 1
