Power Steering Box Removal
Suspension, Steering and Chassis
  1. Bryan Lohmiller
    Bryan Lohmiller Active Member
    37
    1
    Nov 5, 2020
    Elk Grove, CA
    Local Time:
    2:11 PM
    Am I going to need to remove my driver side header to remove my power steering box?
  2. cudamark
    cudamark FABO Gold Member FABO Gold Member
    8,983
    1448
    Mar 14, 2009
    San Diego
    Local Time:
    2:11 PM
    Probably, what year, model, and engine do you have? What headers? maybe a photo of your engine compartment?
  3. Bryan Lohmiller
    37
    1
    Nov 5, 2020
    Elk Grove, CA
    Local Time:
    2:11 PM
    It's a 71 duster with a 360 and TTI headers and it is tight in there was wondering if anyone else had figured out a way to work the box out maybe
  4. cudamark
    8,983
    1448
    Mar 14, 2009
    San Diego
    Local Time:
    2:11 PM
    Sometimes the only way to know is to give it a try. Pull the column, get it up on stands, pull the hoses, remove the pitman arm, unbolt the box, and work the steering back and forth to see if there's enough room to get it out. You might also look at pulling it out the top depending on where the header pipes run and what kind of shift/clutch linkage, master cylinder and booster you may have. Sometimes you can also unbolt the engine mount(s) and jack it up to get extra clearance. Have fun!
    • Agree Agree x 2
    • dano
      dano Evil Handy Man
      4,036
      1870
      Aug 22, 2005
      Gresham, Oregon
      Local Time:
      2:11 PM
      What cudamark said and sometimes the header needs unbolted and the motor jacked over to get it out. This was the procedure on my 66 Coronet to get the starter out with a 440 and headers.
    • Bryan Lohmiller
      37
      1
      Nov 5, 2020
      Elk Grove, CA
      Local Time:
      2:11 PM
      Ya I had to jack up the motor 1/2"-3/4" to get the starter in kept hanging up on the steering linkage
    • Roadart
      Roadart Well-Known Member
      281
      57
      Jun 18, 2018
      Escalon ca.
      Local Time:
      2:11 PM
      Agree, on my 72 dart,loosen headers,Jack up engine a bit and it will come out(via wiggling).
    • Bryan Lohmiller
      37
      1
      Nov 5, 2020
      Elk Grove, CA
      Local Time:
      2:11 PM
      Then it will come out from the top? I hope
    • lenky1
      lenky1 Well-Known Member
      646
      293
      Jul 30, 2014
      illinois
      Local Time:
      4:11 PM
      Agree 100% w cudamark. I loosened driver side motor mount and jacked engine up and snaked it out carefully around the torsion bar. It will come out under the car
    • Bryan Lohmiller
      37
      1
      Nov 5, 2020
      Elk Grove, CA
      Local Time:
      2:11 PM
      This should be interesting then actually once I pull out the LCA's to rebuild them and with the torsion bars out of the way that will make it a lot easier forgot about that. It looks like a spring project then firm feel is 3 months out on there boxes.
    • Bryan Lohmiller
      37
      1
      Nov 5, 2020
      Elk Grove, CA
      Local Time:
      2:11 PM
      If anyone is interested here is how I got it out. It was not coming out the usual way without dropping the headers so I pulled out the battery and tray and I did jack up the engine also and beat it past the header and finder well and came right out through the area where the battery goes.
      • Like Like x 1
