power steering box removel on a 67 barracuda
Discussion in 'Suspension, Steering and Chassis' started by 273 ball, Apr 15, 2018.
  1. 273 ball
    273 ball Well-Known Member
    391
    12
    Mar 12, 2016
    hemet
    Local Time:
    7:56 AM
    hi do I need to take the steering colume lose and back that out I see four bolts on the fire wall .
    what is the best way ? Tyler
  2. xLURKxDOGx
    xLURKxDOGx "An angel fat, at satan's feast"
    2,249
    389
    Dec 27, 2013
    PHX
    Local Time:
    7:56 AM
    Slant or v8? I just did this on my 64 with a commando 273 and it was a pain in my ass! I pulled the drivers exhaust manifold, starter, steering wheel/shaft and lower control arm and it wasn’t easy to hold it up to bolt it back together either. I found having it up on jack stands was the easiest.
    Jake
  3. RustyRatRod
    RustyRatRod Just another dumbass. Technical Editor
    45,963
    10154
    Jun 7, 2010
    Georgia
    View My Photos
    Local Time:
    10:56 AM
    Just take the thing out. It's a 67 model. It will tell you how if you just look.
  4. 273 ball
    391
    12
    Mar 12, 2016
    hemet
    Local Time:
    7:56 AM
    Hi v8 ..
  5. coffeedart67
    coffeedart67 Well-Known Member
    1,156
    23
    May 9, 2010
    Southeast South Dakota
    Local Time:
    9:56 AM
    Just replaced the power steering box on my 67 Dart with a 273 .Pulled starter, took nut off of drivers si
    de motor mount, jacked up engine, pulled steering column, and let gravity help me take it out from underneath. Didn't have enough umph to lift new one from bottom, jacked up engine a little more and was able to lower it in from top, buggered up threads one one hole and had to pull it out to run a tap through it, then box back in.
