RPMagoo
Just An Old Motorhead
Used Power Steering Pump (no Pulley, and no Cap) from a 70 Duster. -- I removed it because of a leak. After I bought a new one, and started to pull the old one off, I found that the line from the steering box was only finger tight, at the pump. This was, likely, causing the leak. Because I already had a new pump, I put the new one on. -- I will ship this for $35 to anywhere in the US - 48 States, and if it leaks, then I will refund the $35, to the buyer.
