a70duster
I have a '72 Duster that came with power steering. I'm currently putting a 383 in there and the power steering system occupies a lot of space. I chose to swap to a manual steering box. I did some research and only found some vague information. Here is the solution I came up with with the advice of others.
I purchases a 3/4" 36 spline to 3/4" hole steering u-joint. They're pretty easy to find on the internet, just pick your favorite flavor. There is about 1 1/2" gap between the steering shaft and the u-joint.
The steering rod needs to be extended about 1 1/2". There are a few ways to do this. After the rod is extended, you'll need to drill a 5/16" hole in the 3/4" part of the u-joint. Add a grade 8 bolt with a locknut on the other side.
This is a low cost solution that other have implemented.
