Have an 71 340. All is well with the exception of power steering. System is operational but it's way too easy to turn to the point of if I'm traveling on roads it feels like if I make a quick movement left or right I could land in a ditch. It's that easy to turn. Zero resistance. I've seen individual's purchase new steering boxes to try to alleviate the problem, but feedback I've read it didn't change the anomaly. Front suspension is tight (ball joints, tie rods, pitman, idler, front bearings, sway bar bushings). Anyone out there experience this? If so, how did you alleviate it?
