Powerglide swap, am I missing anything?
71Demon540
Connellsville, PA
Transmission and converter will be done in 2-2.5 weeks. I got a motion race works shifter ordered, as well as the flex plate and crankshaft adapter from ATI. Other than a driveshaft which will be last, am I missing anything? I know the cross member needs modified. But is there anything else that I need to purchase before making this swap? Anyone have pics of their cars crossmember with a powerglide?
Thanks.
R.J.
Thanks.
R.J.
only part i can think of at the moment is a 727!!!!! :rofl:
are you going aftermarket case or stock case?
Thanks.
R.J.
I was thinking an LS under the hood. But, I won't say that. :poke: :rofl: :rofl:
Thanks.
R.J.
I believe it's customary to use a pop up toaster handle for a shifter when going to a glide lol
I have an ATI Turbo-400 in Krusty. As far as I remember, I believe you have the bases covered.
Maybe an overflow-tank and locking dipstick tube....
ATI makes a real nice overflow tank. I put one on my car. Neat install [between pan and bell], and quick release line.
Korie, i legitimately thought of you when I made this decision and said “Korie is gonna make fun of me for getting a pop up toaster” hahah
Where are you planning to put the 110v outlet is what I wanna know lol
I have that same setup, I needed .120 in shims for the starter so it wasn't hitting the flexplate. I also have a .250 mid-plate, so the starter sits .370 from the bellhousing face.
Thank you! I do not have a mid plate, but I will be purchasing shims in he event I will need them.
