who here runs this alt...........can u use the factory big block mounts.....or do u know what mounts I need...do I need to install a relay at the rear, along with a fuseable link on each end, what size wire do I need to run from the battery in the trunk all the way to the alt at the front, ur help is very much appreciated............thanks............kim.....
