[WANTED] Powersteering pump bracket and pulley
How about these ?
So do u want a TRW set up or a Federal set up. Post a pic of the rear of the pump u will be using. Also post the front pic. Is the pulley bolt on or pressed on? Shaft size. Small or large pulley. Thanks. Kim
Have the brackets for a TRW . Have pulleys that are already pulled but would need to know what diameter you need. Tried to PM but did not work.
