Map63Vette
As the title suggests, what all is even still out there nowadays? Back in the day I remember hearing about Thiteks and Inertia had heads to go with their cams, but lately I'm seeing very little offered for the earlier engines. I know the later heads are better out of the box, but I painted myself into a corner because I had no way of knowing what was coming back when I did my swap ~15 years ago.
I have an Indy ModMan intake for the early 5.7 ports and TTI headers as well. I'd really rather not have to redo everything on the top end if I ever did pull the trigger on some better heads, so I'd like to try to keep to original early 5.7 style ports and bolt patterns. I actually really like that my engine still looks kind of old school with the 4bbl throttle body setup, even if the injectors and rails are obvious if you look lower down.
I've been quite happy with the way my car is running now, but I always have that nagging in the back of my head saying "but could it be better?". It's basically my daily driver, so I'm not looking to compromise it away from that, but I figured some better flowing heads would be one of the "easiest" ways to get a little more punch out of it without redoing a lot of stuff. I've got an Inertia Motorsports SRT Max Plus camshaft in it now and I think I've got my tune to a pretty happy point. I'm not trying to set records or anything, so I'm not pushing it to the limit and trying to squeeze every last drop of horsepower out. Mostly just thinking of what kind of stuff I might be able to do if I wanted to get more without resorting to a whole new engine or forced induction.
