1. swifty
    swifty Well-Known Member
    261
    78
    Feb 27, 2013
    Bismarck, ND
    Local Time:
    6:54 AM
    I have a 72 dart with 73 and up running gear. I am looking for the correct pressure line for power steering. It has a federal pump. I purchased an Edelman 80119 for a 72 accidentally. The hose is shaped right, is the right length, fits the pump fitting but has a female end on steering gear.
    The bottom fitting is what was in the gear. The problem is it does not fit very well and i think it is not the right fitting. 20180710_205543.jpg
    Here is the thread on the steering gear.
    Any ideas on what will fit? Is this an o ring fitting or inverted flare? Rock auto has a Lares 177 5/16 fitting? Kind of confused. I would like to adapt what I have to work but when I went to the parts store to looked totally confused.
  2. TrailBeast
    TrailBeast Slightly Twisted Member
    19,218
    5558
    Mar 11, 2011
    Arizona
    Local Time:
    5:54 AM
    Order for a 73 Dart swinger and you should get the right one (like the one that came off) with the O ring type fitting.
    I got mine for my 73 from Autozone and it came with the new Orings.
    (also male on both ends like your picture)
    • Thanks! Thanks! x 1
    • 4spdragtop
      4spdragtop FABO Gold Member FABO Gold Member
      24,945
      4255
      Aug 28, 2009
      Ontario
      Local Time:
      6:54 AM
      In the 2nd pic the male ends look different.
      • Agree Agree x 1
      • swifty
        261
        78
        Feb 27, 2013
        Bismarck, ND
        Local Time:
        6:54 AM
        I agree and it does not thread on very well. Threads may be bad on steering gear. I think I will remove control unit to get a better look.
      • 67Dart273
        67Dart273 Well-Known Member
        38,632
        6243
        Oct 14, 2010
        Idaho
        Local Time:
        4:54 AM
        That is not inverted flare. I've always thought they were proprietary, "non standard" fitting. I've not seen one like your replacement. Maybe it was an attempt to eliminate the O ring and maybe it's just the wrong fitting.
        • Agree Agree x 2
        • 4spdragtop
          24,945
          4255
          Aug 28, 2009
          Ontario
          Local Time:
          6:54 AM
          Why is there 2 hoses? My 67 has only 1 pressure hose. My return line is held on with hose clamps(no fittings)
        • swifty
          261
          78
          Feb 27, 2013
          Bismarck, ND
          Local Time:
          6:54 AM
          There is one hose. The picture is each end of the same line. It had a number adaptors to get to a universal hose. I am just not sure what the fitting for the steering gear is suppose to be. I am not sure what the control valve on the steering gear came from, 72 or later. V8 or /6.
          • 4spdragtop
            24,945
            4255
            Aug 28, 2009
            Ontario
            Local Time:
            6:54 AM
            So in 1st pic, the 2 lines hook together. Here is a pic of my factory monstrosity.
