694spd
Was at a friend's garage today and he is working on a Prestolite dual point distributor from a 68 340 Barracuda. He thought that the distributor and a worn shaft bushing, but I noticed that it's actually the cam that is loose on the shaft. You can move the cam a little from side to side while the shaft is staying stationary. You can see this when looking down at it from the top.
Can this problem be corrected?
