Printed circuit connector
Dodge73Dart
1973 Dodge Dart Sport restoration
Asheboro North Carolina
I am looking for a diagram actually listing the connector use for each pin of each one.
http://www.mymopar.com/downloads/1973/73DartB.jpg
what does each pin provide for? I have the complete diagram but it seems almost impossible to correctly identify what each pin provides power for.
I have built a custom cluster and now need to build a new plug for the cluster.
I have the car apart for now so no I can't meter the plugs.
Thanks to all.
Update: I sat down with the diagram and need to know if you all agree with my findings:
Pin Use
1 12 Volt feed
2 Fuel
3 Temp
4 Instrument lamps
5 High Beam Ind.
6 Left Signal
7 Right Signal
10 Emer./ Low Brake
11 Oil Pressure
Hopefully I have this all right. I am sure someone here will corract me if wrong! Thanks
I don't understand the problem. On a side note, you can also download the factory manual from MyMopar, which, by the way, came from some of the guys right here
Standby..........
OK LOL, pin 2 is a mistake. Shows it going to pin2 of the connector which in turns supposedly goes pink to the dome light That is wrong
This is from page 8-167 of the factory manual
The MyMopar diagram
Standby..........
Pin 2 is blue.
Darnit I THOUGHT that in that section 8 there was a circuit description showing wire color/ circuit coding
I think you have the numerical listing right according to MyMopar. The two connectors are show mirror image from each other. If you look at the rear of your cluster and follow the traces, you can easily confirm where they go.
In fact do you have a way of posting a couple of good clear shots of the rear of the cluster, and a front view?
