Pro Billet Dissy ?
Big Block A body Tech
  1. 70wayfarer
    70wayfarer Well-Known Member
    409
    25
    Jul 20, 2011
    new zealand
    Local Time:
    4:32 PM
    hey guys, i'm using a pro billet dissy #8546 for the first time. engine is a 500 rb stroker, msd digital 6 box. running 93 pump, dynamic cr around 8.6, brodix heads. 1050 dominator, this is a street strip car. she idles around 900 ish warmed up.
    anyways just wanting to know what a good starting point would be for selecting advance curve springs and advance stop bush. cheers
  2. SPACECOWBOY
    SPACECOWBOY Well-Known Member
    211
    169
    Sep 6, 2015
    St.Louis
    Local Time:
    11:32 PM
    Lock it out.
  3. IQ52
    IQ52 Well-Known Member
    2,260
    1446
    Jul 30, 2011
    Idaho
    Local Time:
    10:32 PM
    And the cam duration at .050" is?
    • Like Like x 1
    • 70wayfarer
      409
      25
      Jul 20, 2011
      new zealand
      Local Time:
      4:32 PM
    • roccodart440
      roccodart440 Well-Known Member
      5,017
      4004
      Apr 19, 2010
      Local Time:
      12:32 AM
      I run 18/35 all in at 3500 with my pro billet but I can't tell you which springs and bushings I used. MSD is pretty clear which colors do what and if you don't have the paperwork it's on their site.
    • AndyF
      AndyF Well-Known Member
      1,201
      799
      Feb 23, 2009
      Oregon
      Local Time:
      9:32 PM
      That is a fairly primitive distributor so you'll just have to do the best you can. First step is to set the total advance where you want it which is probably somewhere in the low to mid 30's. I've never run the Brodix heads so I can't tell you how much advance they want but I'd start at 32 and work from there.
      Advance at idle will depend on the bushing size you install. A performance cam will typically want a fair amount of advance at idle but with the black bushing you'll be limited to what you can give it. The advance curve will depend on a bunch of other factors but typically for a performance application you'll want the advance to come in fairly quickly. As pointed out above, all of this info is in the instructions.
    • IQ52
      2,260
      1446
      Jul 30, 2011
      Idaho
      Local Time:
      10:32 PM
      Yep, that is one you could probably lock. But if you use some mechanical advance, I would start with a minimum of 26 advance at idle and 32 degrees total. With that distributor I've always had to make my own bushings to set that small amount of mechanical advance.
      • Thanks! Thanks! x 1
      • SPACECOWBOY
        211
        169
        Sep 6, 2015
        St.Louis
        Local Time:
        11:32 PM
        Mine was lazy off idle untill I locked it out. It didn't matter what springs or weights I tried.
        • 70wayfarer
          409
          25
          Jul 20, 2011
          new zealand
          Local Time:
          4:32 PM
          for what i'm using the car for i locked it out. starts good and idles not to bad.
        • crackedback
          crackedback FABO Gold Member FABO Gold Member
          17,956
          2079
          Aug 7, 2005
          92201
          Local Time:
          9:32 PM
          I have 10 and 14* bushing for MSD distributors if you want a curve in it.
          • Like Like x 1
