1970 La
I started mocking up my engine with the w2's. Was wondering about my t&d rockers I had to shim the bar up .140 to get the valve tip to run in the center of the valve does this seem like a lot of shim? I called t&d and they said it would be fine so thats what i will go with. (.600 lift) 5.300 long valve.
The pushrod length is another concern looks like 8.370 but i am goining to wait on them until i get the heads milled and the valve job done. Looks like a lot of grinding is going to be needed to clear the push rods. I was hopping that someone here has used theese same heads. 65cc push rod oiling. thanks
