problem with ram 1581 and ram power grip clutch set factory bolts will not go thru pressure plate but fit flywheel ?
gt273
Member
pittsburgh
Mine had Special Scalloped Bolts... not the same Clutch tho. (Borg and Beck 3 Finger)
This was a 10" Upgrade from the Stock 9 1/2" for a '65 273
Do you, by chance have the part number for the bolts attaching the pressure plate on the 10" upgrade?
Thank you.
Yup, you're going to need those bolts. Even if you drill out your pressure plate, you won't have enough room to get a socket on those bolt heads.
picture 1- factory flywheel with bolts for 10 inch clutch aftermarket. ram powergrip clutch bolt pattern will not fit factory flywheel. factory takes 5/16 bolts
picture 2- ram clutch and ram flywheel installed after drilling pressure plate for factory 3/8 pressure plate bolts. ram flywheel takes 3/8 bolts
3- restored every nut and bolt from engine to rearend.
i used this setup so i could install dana 60 3.54 did not trust aftermarket 10 in and china clutch with this setup
everything works perfect ,clutch pedal returns perfect and smooth.
