Procharged '67 Dart
Discussion in 'Forced Induction Mopar' started by nitrojunkee, Aug 17, 2018.
  1. nitrojunkee
    nitrojunkee Well-Known Member
    393
    51
    May 4, 2012
    Denver
    Local Time:
    12:01 PM
    After 5 1/2 years, this car is in the final stages of what I had originally planned for it, so I thought I'd share with you guys. A lot of blood, sweat and tears of not only my own, but my good friend (Who I couldn't have done all of this without) went into this car.
    Anyway, The Great Pumpkin is a Procharged 496" raised deck with a set of really well ported (by my buddy) RPM heads, CSU blow through carb, M1 intake, Bullet custom grind solid roller, T&D rockers, custom Diamond blower pistons, K-1 crank, Scat H-beams and Milodon single line external oiling system, with their road race pan. We converted the front end to an Alterktion and put Wilwood disc brakes on the front and rear. I had John Cope put together a 727 Super Pro Trans Brake transmission for it, with a Mark Williams Accu-Bond 7075 driveshaft. The rear is a narrowed D60 with a Detroit Locker and Mark Williams Pro Street axles. CalTrac's with a monoleaf setup for rear suspension. I called Rich Bogart and had them build a set of custom one off wheels for the car, the rears are a single bead lock style. That's about the gist of it! We have a little electrical cleanup and tuning to do, but that's about it for a while. I thought you guys might like to see something a little different and a car that I'm really proud of, thanks for looking!
    • Like Like x 15
    • Disagree Disagree x 1
    • fklskv
      fklskv Well-Known Member
      848
      334
      Aug 14, 2011
      Lackawanna, NY
      Local Time:
      2:01 PM
      Compliments to the wrenches!
      • Thanks! Thanks! x 1
      • Matts440
        Matts440 FABO Gold Member FABO Gold Member
        1,721
        643
        Apr 11, 2014
        Riverside, CA
        Local Time:
        1:01 PM
        She's a beauty, nice work done.
        • diymirage
          diymirage HP@idle > hondaHP@redline
          14,326
          6602
          Oct 12, 2012
          michigan
          Local Time:
          2:01 PM
          i gave you the big red X, because to post pictures oh this and no 1/4 mile video is just plain teasery
          • Like Like x 2
          • Walker434
            Walker434 Well-Known Member
            780
            349
            Aug 29, 2012
            Nashville, TN
            Local Time:
            1:01 PM
            Cool build! How much boost you running? I just put a Procharger on my small block 71 Dart.
            • brian6pac
              brian6pac Well-Known Member
              3,009
              1506
              Nov 15, 2016
              N.E.Ohio
              Local Time:
              2:01 PM
              I like it, nice job guys
              • mopardude318
                mopardude318 Well-Known Member
                10,721
                350
                Jan 7, 2005
                Gilroy, Ca
                Local Time:
                11:01 AM
                wow. excellent work! Post more pics please! engine compartment, interior, underside!!
                • nitrojunkee
                  393
                  51
                  May 4, 2012
                  Denver
                  Local Time:
                  12:01 PM
                  Haha! It will be a while before it sees a track... It's a purpose built street car. ;)
                • nitrojunkee
                  393
                  51
                  May 4, 2012
                  Denver
                  Local Time:
                  12:01 PM
                  About 6psi on pump gas right now. But I'm also at close to 6000' in Colorado. Good luck!
                • diymirage
                  14,326
                  6602
                  Oct 12, 2012
                  michigan
                  Local Time:
                  2:01 PM
                  thats real cool
                  can you get us some video like this?
                • nitrojunkee
                  393
                  51
                  May 4, 2012
                  Denver
                  Local Time:
                  12:01 PM
                  Sure can. I intend to this fall after some tuning and testing.
                  • famous bob
                    famous bob mopar misfit
                    11,013
                    2668
                    Aug 14, 2011
                    okla
                    Local Time:
                    1:01 PM
                    ARE U NOT WORRIED ABOUT SPLITTING THE BLOCK ??
                  • nitrojunkee
                    393
                    51
                    May 4, 2012
                    Denver
                    Local Time:
                    12:01 PM
                    No I'm not. Like I said, I'm at 6,000' of elevation so we are already down on power quite a bit. On 6psi of boost I've basically just made up what I lost from sea level, plus a little more. It's only making about 650-700hp at the most right now. At sea level it would be 800+ easy, and then I would be worried.
                    Also, why are you yelling at me?? I don't remember doing anything to you! Lol :p
                  • Divenut
                    Divenut Well-Known Member
                    2,619
                    711
                    Sep 22, 2011
                    Naperville Illinois
                    Local Time:
                    1:01 PM
                    Gorgeous! Nice job man.
                    Pat
                    • Like Like x 1
                    • nitrojunkee
                      393
                      51
                      May 4, 2012
                      Denver
                      Local Time:
                      12:01 PM
                      Thanks a lot!
