ProForged tie rod sleeves (thumbs down)
Bad Shrimp
Tacoma, WA
I purchased 4 billet tie rod sleeves made by ProForged, only 1 is threaded correctly and works as intended. Proforged won't respond to my calls, messages, emails.
I recomend a no buy :wack:
P.S.
The parts look awesome though.
Did you but them direct or through a vendor. If vendor I'd return or exchange them.
Returning to Summitracing. Buying stock replacement parts from AutoZone rather than fancy CNC parts.
We offer them in solid steel if you are interested in 9/16" or 11/16"9/16" Sleeves http://www.p-s-t.com/s.nl/it.A/id.9500/.f?sc=1211/16" Sleeves http://www.p-s-t.com/s.nl/it.A/id.7076/.f?sc=12Thanks James
Thanks for the heads up. I actually saw those on the website but I was confused by the wording on the part description, I obviously should have called PST. I'll be buying a few of the other suspension and steering parts P-S-T offers.
Separate issue.......... Firestone has a life time alignment offer that is $170 for those that are slowly upgrading their front suspension and steering like me and will need multiple alignments.
