Budgetmoparman
I am looking to upgrade the heads on my stock 383. It currently has 516 casting heads on it now. I don't know the compression ratio, it is a stock 67' 383 truck motor, no wild cam or high performance build by any means. I am running an 850 thermoquad with cast iron intake and shorty headders. Looking for advice on which head I should get. I am hoping to build a 400 based 470" stroker in the future when the budget will allow it. Would either of these heads work on the stroker? Is there a different head I should get instead?
440 source stealth
Intake port 212cc
Exh port 72cc
290cfm
80cc closed chamber
2.14" & 1.81" valves
Promax 9440 performance series
Intake port 210cc
Exh port ???
295cfm
84cc
440 source stealth
Intake port 212cc
Exh port 72cc
290cfm
80cc closed chamber
Intake port 210cc
Exh port ???
295cfm
84cc
