Humor me;
Back the Idle timing off to 8 degrees,
Set the T-slot to square,
make sure the secondaries are fully closed,
set the mixture screws to 3/4 turn out,
make sure the WET fuel level is correct and stable,
Flip the PCV out of the grommet, seal both VCs, and
Put the vacuum gauge on the dipstick tube.
DO NOT CHANGE THE SPEED SCREW SETTING.
Start it up and immediately check the vacuum gauge;
If you have vacuum there, your intake gasket is leaking into the valley.
Pressure is normal but do not exceed 4psi, as that can blow seals or gaskets OUT.
If yur normal, then put the PCV back in the grommet and reinstall the breather.
Now, if you still have a high idle; do you have an EGR valve? If yes, then make sure the circuit is not leaking thru the diaphragm, nor sucking exhaust into the plenum.
That's a pretty small cam, I'd idle that down to 600 in gear, up to 700 in N/P..
That 650DP is a great carb for your application. It should be snappy as heck.
Industrial Materials & Equipment
After you get the idle back to a normal speed, reset your Accelerator pump slack, then check for a tip-in hesitation. If you got one, you gotta fix this before you do anything else. How you do it is to add transfer fuel, while simultaneously subtracting Mixture screw fuel. Just a tiny bit atta time.
After you get that done;
If the Idle speed needs adjusting;
More Idle-Timing will make it run faster,
and less will get you slower.
But more timing with a stock convertor will make it bang into gear. Try to get the rpm DIFFERENCE from in-gear to in-Neutral to less than 150 rpm to prevent the banging.
The higher your Idle-timing gets to be, the more Idle power she will make, and the higher the Idle-rpm will go. Which after 800rpm or so, starts to bang pretty hard on the stock convertor.
There is no good reason to run more idle timing than is absolutely necessary.
After you get the Idle set-up, then begins the task of modifying your Distributor to hit the other targets of;
Power-timing, stall-timing, rate of advance and cruise-timing.
HappyHotRodding.
