It’s almost there. I put a much smaller IAB in trying to get my tip in cruise richer, but then realized I have a vacuum leak which is obviously leaning the entire circuit, and also most likely the reason why it idles so high to the point where I have to cover the t slot to get it down to where I want it.
So my first step is to put the idle circuit back to stockish (0.028” IFR and .070” IAB) after fixing that vacuum leak. Square the t slot, and then see where my idle ends up. I’ll get it fully warmed up then map my timing curve and compare to the moroso charts and see where I should go from there.
