There's a limited working range of initial throttle position where the transfer slot will function effectively as the throttle opens.
When tuning in neutral, which has to be done with a manual transmission, reducing the initial timing from 18 will slow the engine. Then if it was wanted to return the idle to 750 rpm, the throttle has to be cracked open a little more or some air needs to be bled in. Then the idle mix screws should be adjusted.
Working the other way, if the throttle is cracked open a bit more, then to bring the idle rpms down, reduce the timing a bit.
T-slot square is just an easy visual to put in the ballpark. On 4777 .020 to .040 is probably the working range.
So if I went down to 14 degrees (and fixed the vac leak), and the t slot was at .040 and still too slow an idle, but I don’t want to change timing, then I’d open the secondaries slightly in this context correct?
