1. pishta
    pishta I know I'm right....
    13,912
    3617
    Oct 13, 2004
    Tustin, CA
    Local Time:
    11:21 AM
    Maybe you guys are talking about 2 different PST 1.03 rods. Early straight cast and the newer -20 degree jobs? I know my 340 bars had to be removed with the LCA's hanging free AND turning them even farther down with a huge pipe wrench. Id assume the much stiffer rods would be installed with less of an initial downward deflection if the bar allowed it.
  2. plumkrazee70
    plumkrazee70 Well-Known Member
    1,848
    312
    May 5, 2013
    Medford, Oregon
    Local Time:
    1:21 PM
    Mine are the newer clocking not zero.
  3. plumkrazee70
    1,848
    312
    May 5, 2013
    Medford, Oregon
    Local Time:
    1:21 PM
    Ok... Update.
    I lowered the LCA all the way down with the bump stop out, and this is what it looks like. The bump stop is still out.
    @PST what do you think? It looks good to me and it can be raised if necessary for alignment.
    • Like Like x 1
    • MobileCustoms
      MobileCustoms Well-Known Member
      1,463
      948
      Oct 21, 2013
      Inver Grove Heights, MN
      Local Time:
      1:21 PM
      Well, Here's a photo of mine from yesterday. I had installed the 1.03 torsion bars with the LCAs hanging down and in this photo, the adjusters are all the way loose. The rear has brand new ESPO plus 1 inch 6 leaf springs in it and the tires are 295/50/15, 26" tall. I think it sits a little high, overall. Will probably try re-clocking the torsion bars if possible. Then, maybe a lowering block for the rear end... Not at the top of my list right now because there's lots of other things that need to get buttoned up!
      IMG_20190320_171335769_HDR.jpg IMG_20190320_172401273_HDR.jpg IMG_20190320_172804464_HDR.jpg
    • plumkrazee70
      1,848
      312
      May 5, 2013
      Medford, Oregon
      Local Time:
      1:21 PM
      Yep, same thing happened to me. I had to re clock the bar. Pretty quick to do, actually. Just jack it up, pull the bar out, rotate until the next hex and try again. I did one side at a time.
      • Like Like x 1
      • daves66valiant
        daves66valiant Hibernation over. 1968 Dart V8 swap in full swing FABO Gold Member
        2,946
        806
        Nov 24, 2005
        SoCal
        Local Time:
        11:21 AM
        It does look high like my original install. It’s is easy to re-clock. I have taller tires in the back 28”. My 6 leaf espo springs are “0” stock height.
        What I’m finding is that I may need to get shorter bump stops for the LCAs. I had read in another post that some guys have done this. I may take a sander to mine and flatten the peak out a little (1/4”)
