PST 16:1 Box excessive play
Suspension, Steering and Chassis
  1. plumkrazee70
    plumkrazee70 Well-Known Member
    3,092
    951
    May 5, 2013
    Medford, Oregon
    Local Time:
    4:43 PM
    I just got my car on the road and there is an excessive amount of play in the steering wheel. I finally was able to get a helper and with the wheels off the ground, had him rock the steering wheel back and forth, while I checked for play. I immediately found it out of the box. https://youtube.com/shorts/c5XIJ-rUMJE?feature=share
    What's disappointing is that the box is brand new, it has virtually no miles on it.
    Do you think this will adjust out or do I need a replacement? I sent a shortened video to @PST to get their thoughts.
    Thanks.
    70 Dart, 16:1 manual steer.
  2. PST
    PST Marketing Manager FABO Vendor
    946
    484
    Apr 22, 2009
    Montville, NJ
    Local Time:
    5:43 PM
    Hello,
    Please reach out to our customer service manager Dan at extension 306. You should not have lateral movement like such. I will be sending a him this link as well so that he can view the video. I do apologize for the inconvenience. We will get a replacement box sent out.
    James From
    PST
    • Like Like x 2
    • Thanks! Thanks! x 1
    • abodyjoe
      abodyjoe Well-Known Member
      22,168
      8822
      May 22, 2004
      Berlin,N.J. 08009
      Local Time:
      5:43 PM
      oh man that blows.. i'd like to get rid of my crappy stock box in our dart but all i see is issues with the pst box and the borgeson box posted on various forums.. with my luck i'm sure to get a bad one of whichever i decided to buy.. i just can't bring myself to spend the money on either box as i don't trust the after purchase support with either product...
    • brian6pac
      brian6pac Well-Known Member
      5,668
      4027
      Nov 15, 2016
      N.E.Ohio
      Local Time:
      5:43 PM
      I have had 2 Chevy 1500's, 1 GMC 1999 and all had the small P/S box by borgeson from the factory. one truck had 300,000 miles in it another one has 200,000 on it and still going strong
    • PST
      946
      484
      Apr 22, 2009
      Montville, NJ
      Local Time:
      5:43 PM
      We have seen very few issues with our boxes. In the few cases that we have had most of the time the issue could be resolved by making adjustments to the box following the factory service. Now in a case like this we acknowledge there is an issue and there should not be lateral play. So a replacement will be sent our immediately.
      We have sold 733 of these boxes over the past 5 years with little to no issues and if there is one we have worked with the customers.
      James From
      PST
      • Like Like x 5
      • Thanks! Thanks! x 2
      • plumkrazee70
        3,092
        951
        May 5, 2013
        Medford, Oregon
        Local Time:
        4:43 PM
        Thanks, James. I will be sure to reach out to Dan right now.
      • abodyjoe
        22,168
        8822
        May 22, 2004
        Berlin,N.J. 08009
        Local Time:
        5:43 PM
        That's all great but they aren't the ones made to go into an old mopar.
        Ya see everything from they sit on an angle (seemed to be earlier ones) to they are loud to this post about the pst unit.
      • plumkrazee70
        3,092
        951
        May 5, 2013
        Medford, Oregon
        Local Time:
        4:43 PM
        @PST left Dan a message.
      • Lord Sparky
        Lord Sparky Well-Known Member
        702
        536
        Dec 2, 2019
        Carlsbad, California
        Local Time:
        2:43 PM
        Flaming River.
        • Agree Agree x 1
        • brian6pac
          5,668
          4027
          Nov 15, 2016
          N.E.Ohio
          Local Time:
          5:43 PM
          Now that I look at it it is real close to being the same, Borgeson fast ratio GM uses the Delphi 600 box and that it what I have and the box they use for the Mopar is a copy of that it looks like.
        • plumkrazee70
          3,092
          951
          May 5, 2013
          Medford, Oregon
          Local Time:
          4:43 PM
          Got a call from Dan from @PST. New box on the way.
          While, I am not looking forward to the install, glad they stepped up so quickly. ☺️
          • Like Like x 3
          • plumkrazee70
            3,092
            951
            May 5, 2013
            Medford, Oregon
            Local Time:
            4:43 PM
            @PST I got the new box today. The invoice says 16:1, but when I turn the shaft by hand it takes, what seems like a lot of turns from lock to lock. Maybe it's deceiving because it's not in the car?
          • AUSA66
            AUSA66 Well-Known Member
            265
            346
            Nov 20, 2014
            Perth
            Local Time:
            6:43 AM
            I had the same problem with a Borgensen box new once i adjusted the free via the adjuster it disappeared they will probaly give you similar advise
          • PST
            946
            484
            Apr 22, 2009
            Montville, NJ
            Local Time:
            5:43 PM
            How many complete turns are you getting when turning the portion of the box that attaches to that column ?
            James From
            PST
          • plumkrazee70
            3,092
            951
            May 5, 2013
            Medford, Oregon
            Local Time:
            4:43 PM
            I turned it all the way to the left and counted 2 1/4, so maybe it was just me.
            Also, what the best way to be sure the box is centered when installing? I was thinking turning it all the way one way and then going back until I saw the grooved spline pointing straight
          • PST
            946
            484
            Apr 22, 2009
            Montville, NJ
            Local Time:
            5:43 PM
            The 16:1 is 2 1/4 clock to clock and you method for centering will work.
            Thanks
            James From
            PST
            • drewmac
              drewmac Well-Known Member
              353
              116
              Jun 7, 2012
              Lacey, Wa
              Local Time:
              2:43 PM
              I have the same exact problem with my PST box. Sending it back to them.
            • drewmac
              353
              116
              Jun 7, 2012
              Lacey, Wa
              Local Time:
              2:43 PM
              James I have a return invoice for a problem just like this. Should I just send the box back still and await a replacement?
            • plumkrazee70
              3,092
              951
              May 5, 2013
              Medford, Oregon
              Local Time:
              4:43 PM
            • abodyjoe
              22,168
              8822
              May 22, 2004
              Berlin,N.J. 08009
              Local Time:
              5:43 PM
              Oh well. Guess I'll officially scratch this box off of my list of things to buy.
            • plumkrazee70
              3,092
              951
              May 5, 2013
              Medford, Oregon
              Local Time:
              4:43 PM
              I mean, it sucks to get it and have it be "bad". But I'll tell you I bought a his box in 2019. I sent James that video and he had it all set so when I called their customer service, he verified my address and resent another one. No questions, asked. That is the best customer service you could ask for.
              And the new one came and so far (haven't driven it yet) it's perfect.
            • abodyjoe
              22,168
              8822
              May 22, 2004
              Berlin,N.J. 08009
              Local Time:
              5:43 PM
              That's all fine and dandy but I'm not into doing things (especially steering boxes) twice.
              • Agree Agree x 1
              • plumkrazee70
                3,092
                951
                May 5, 2013
                Medford, Oregon
                Local Time:
                4:43 PM
                I hear ya.
              • PST
                946
                484
                Apr 22, 2009
                Montville, NJ
                Local Time:
                5:43 PM
                Did you reach out and speak to some one in our customer service as of yet? If not please call 800-247-2288 extension 307 and they will work with you.
                Thanks
                James From
              • drewmac
                353
                116
                Jun 7, 2012
                Lacey, Wa
                Local Time:
                2:43 PM
                Yes. I have a return invoice. I'll PM you the info.
