Pulling a 5th wheel RV trailer with a 1/2 ton.
General Discussion
  1. straightlinespeed
    straightlinespeed Sometimes I pretend to be normal Staff Member FABO Gold Member
    10,223
    3701
    Oct 21, 2012
    Oakdale, MN
    Local Time:
    6:15 AM
    I know all about payload, tow ratings, etc... Im looking for first hand knowledge from someone that has done it and there experience pulling a 5th wheel RV with a 1/2 ton truck. If so what length and estimated weight of the tongue and trailer, if you recall?
  2. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    52,072
    37379
    Jan 18, 2006
    Iowa
    Local Time:
    6:15 AM
    How much does it weigh and how much tongue weight? Single axle or tandem?
  3. straightlinespeed
    10,223
    3701
    Oct 21, 2012
    Oakdale, MN
    Local Time:
    6:15 AM
    Thats what Im asking. :lol: I dont have one, but tossing it around. Just looking for anyone that has done it and their experience..
    • Like Like x 1
    • fishmens67
      fishmens67 Well-Known Member
      8,272
      5885
      Nov 10, 2012
      idaho
      Local Time:
      6:15 AM
      If you ask me you're asking for trouble. Pure white knuckle driving with an over loaded truck. lol
      I have pulled everything with trucks, horse trailers, 33' twin engine boat, campers, 5th wheels , car haulers etc.
      I prefer a 1 ton for all towing. A 3/4 ton is workable in most situations and 1/2 ton is good for towing small campers under 25'and small boats under 20'.
      When towing you want to be safe and comfortable with reliability.
      • Agree Agree x 3
      • Like Like x 1
      • Jadaharabi
        Jadaharabi FABO Gold Member FABO Gold Member
        7,492
        8128
        Jan 8, 2016
        Peoria, Illinois
        Local Time:
        6:15 AM
        I have pulled many and all kinds of trailers with differant trucks. For 1/2 tons go for the longest wheel base you can and don't use a short bed.
        Safest is a dually. Arrive alive.
        • Like Like x 3
        • straightlinespeed
          10,223
          3701
          Oct 21, 2012
          Oakdale, MN
          Local Time:
          6:15 AM
          They make 25' 5th wheel campers, and there are a bunch of 25-26' 5th wheels for sale right now. Brand new they advertise 1/2 tow-able. I dont want to buy new, so it would be used, which Im guessing are going to be much heavier than the newer ones. I've towed larger trailers (all bumper pull and the use of WD hitches), my last RV trailer was 27' hitch to bumper. I certainly would not go any bigger than that. So I know all about the safety aspect of towing trailers. Getting into a 5th wheel style is new to me though, and with my 2012 Ram 1500 with Coil springs and air bags Im not so sure about it. Maybe if it had leaf springs it may be a different story?!?!? I've heard since the load is centered over the rear axle its much easier to pull and more stable. I would hate to buy one and dread pulling it across the country. Hence my reason for asking the question..
        • Jadaharabi
          7,492
          8128
          Jan 8, 2016
          Peoria, Illinois
          Local Time:
          6:15 AM
          Your half ton Dodge pickup truck has a 9 1/4 rear axle. The axle bearings use the axle itself as the bearing race. I personally do not recommend that you pull a gooseneck or fifth wheel trailer using that rear axle.
          • Like Like x 1
          • straightlinespeed
            10,223
            3701
            Oct 21, 2012
            Oakdale, MN
            Local Time:
            6:15 AM
            Good to know!
          • SGBARRACUDA
            SGBARRACUDA ROY FABO Gold Member
            17,324
            6049
            Dec 7, 2006
            PLANT CITY FL. and PERRY GA.
            Local Time:
            7:15 AM
            Years ago I had a F-150 1991 and I bought a new23’ fifth wheel. Went all the way from Tampa Fl to Niagara Falls. It did ok. What I learned was the trailer was to small for the three of us. Then I bought a 40’ and had to get a new diesel F-250 to pull it. It was two damn big. Couldn’t get in a lot of camp grounds. Third one was a 28’ Carriage with a super slide and a new 95 Dodge 2500 4x4 club cab. That was the perfect combination. The best fifth wheel size for pulling and camping is 28-32’.
            • Like Like x 2
            • 70 Buster 340
              70 Buster 340 Carbon Footprint FABO Gold Member
              1,140
              1314
              Aug 9, 2019
              Space Coast, FL.
              Local Time:
              7:15 AM
              1978 Chevy Big-10 Silverado w/ a 1977 27ft Coachman. Don't remember the weight. Modern 5th wheels are built lighter for sure.
              350 4 bolt main, Built Turbo 350, 14 bolt 3:73 ratchet locker, dual fuel tanks, H pipe duals
              Pulled great. Sure miss that truck.
              • Like Like x 2
              • 67Dart273
                67Dart273 FABO Gold Member FABO Gold Member
                44,513
                12039
                Oct 14, 2010
                Idaho
                Local Time:
                4:15 AM
                This is true of a LOT of light trucks. GM did this "way back when." I'm not sure if Ford did or not
              • fishmens67
                8,272
                5885
                Nov 10, 2012
                idaho
                Local Time:
                6:15 AM
                I've seen a lot of Chevy 1/2 tons on the side of the road, Broke. lol
                They were over loaded with firewood and at least one axle hanging out cockeyed. lol many trucks !
              • 70 Buster 340
                1,140
                1314
                Aug 9, 2019
                Space Coast, FL.
                Local Time:
                7:15 AM
                "C-Clip" 10 or even 12 bolt yes ... Not with the 14 bolt rear.
              • SGBARRACUDA
                17,324
                6049
                Dec 7, 2006
                Local Time:
                7:15 AM
                But a 14 bolt isn’t in a 1/2 ton.
                • Agree Agree x 1
                • 70 Buster 340
                  1,140
                  1314
                  Aug 9, 2019
                  Space Coast, FL.
                  Local Time:
                  7:15 AM
                  It is in a Big-10 or GMC Heavy Half..
                  I ordered that truck new. The only new vehicle I ever sat down and spec'd out everything and ....waited.
                  Bought in 1978 and Sold it in 1992 with 205,000 miles and the rear only had fluid changes.
                  I did get a trans rebuild at about 120k, Build by a local company called "Level 10" with a 'towing convertor'
                  After 15 salt road winters the rust got to it. The pictures above are from 87 and 88
                • oldkimmer
                  oldkimmer FABO Gold Member FABO Gold Member
                  16,258
                  4722
                  Nov 11, 2006
                  Kindersley, Saskatchewan,
                  Local Time:
                  6:15 AM
                  Like everyone says 25 ft is about the limit. If ur pulling where there is hill it will be a struggle unless u have a hemi in ur truck. I’ve towed with 1/2 tons with 318/360s and found on the hills they were weak. I built my ramcharger for towing with a 360 LA. It did good with a 24 ft bumper pull. I got a diesel in 2001 and never looked back. Oil and fluid changes, tires and brakes. Their good trucks. Kim
                • halfafish
                  halfafish Damn those rabbits, and their holes! FABO Gold Member
                  1,696
                  1495
                  Aug 14, 2016
                  SW Washington
                  Local Time:
                  4:15 AM
                  IMHO, pulling that much trailer with a half ton is asking for trouble. It might be able to pull it, but of far more importance is being able to stop it and control it downhill, on curves, or in an emergency braking event. A half ton is fine with a smaller utility trailer. But a 5th wheel with its higher wind profile and center of gravity it's likely to put you in a ditch. I'd want a 3/4 ton minimum for what you are planning. Just my thoughts from 40+ years in trucking pulling all kinds of equipment and trailers.
                  • Agree Agree x 1
                  • RustyRatRod
                    RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
                    63,751
                    36529
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    7:15 AM
                    I've never done it but I had a friend who did. Pulling it wasn't the trouble. Pulled it great. Stopping was another thing altogether. He ended up with an F350 Powerstroke dually.
                    • Like Like x 1
                    • Jadaharabi
                      7,492
                      8128
                      Jan 8, 2016
                      Peoria, Illinois
                      Local Time:
                      6:15 AM
                      Another thing to consider is driver stress. You wount realize it untill you experance it.
                      With a light truck you are working against the wind and condition of the road and keeping your outfit safely going down the road at a safe speed. With a dually you get in the truck and the next thing you know is your there.
                    • ragtopfury
                      ragtopfury Well-Known Member
                      2,783
                      2274
                      Jul 14, 2011
                      Manchester, MD
                      Local Time:
                      7:15 AM
                      1st hand experience here. 97 Ram 4x4 1500 extended cab short bed - a real 6.5' short bed, not today's less than 6ft bed. 360, auto, 3.7something gears, factory tow package. Pulled a new 2006 30ft Rockwood ultra light 5th wheel for 2 years with it. Probably a total of 14 trips, ranging from 90 min to 11 hours in a day depending were we were going. The camper's loaded GVWR was 8150 lbs. It's shipped weight was down around 6950 lbs. Pin weight was 1050 lbs. So i was just about at the max rating for my truck all around. Other than 8 miles to the gallon when towing, that truck handled it great. And the 30 ft camper just "fit" . It was a very comfortable combination.
                      Since the family was growing and the extended cab was getting small, I moved up to an 05 2500 diesel 4 door short bed with plans to buy a bigger camper in the future. We now have a 35ft unit that specs out weight wise at the limit of this truck. Been towing it for 7 years. No issues and handles great, but I'd rather have a 30-32 ft camper. She needed the extra space. LOL
                      Oh, and the slider hitch "they" will try to sell you? With a 6.5ft bed, I've never had one. I can get almost 90* backing in if needed. The hitch pins are all somewhat extended on almost all newer 5th wheels.
                    • Bad Sport
                      Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
                      37,633
                      18450
                      Jun 12, 2010
                      The Wolverine
                      Local Time:
                      7:15 AM
                      We had a Dutchman 27' Bunkhouse that weighed in around 6700 pounds. I pulled it with both of my 3/4 ton trucks one with a V10 the other a Hemi. No problem pulling it, but I was glad I had 3/4 ton when it came time for a panic stop. I'm not real sure I would want to pull it with a half ton (more specifically try and stop it), if'n you had to stop quick that 1/2 ton might get squirrelly on you.
                      They do make shorter 5th wheels that may work for you though.
                    • Krooser
                      Krooser Reform School Graduate
                      2,634
                      2128
                      Jul 19, 2015
                      Central Wisconsin
                      Local Time:
                      6:15 AM
                      Install a set of Timbren overloads on the rear and you will be fine.
                      9 1/4 rears are built just like a standard car rear axle. They do not use the axle tube as a bearing race. Not a "floater" rear by any means but strong enough with a normal load.
                      There are plenty of light weight modern trailers available...
                    • Slowswinger
                      Slowswinger Well-Known Member
                      703
                      892
                      Jul 9, 2014
                      Montana
                      Local Time:
                      5:15 AM
                      I don't know how you will have enough brakes.
                    • diymirage
                      diymirage HP@idle > hondaHP@redline
                      20,008
                      14263
                      Oct 12, 2012
                      michigan
                      Local Time:
                      7:15 AM
                      here is a silly thought...5th wheels dont have trailer brakes?
                    • ragtopfury
                      2,783
                      2274
                      Jul 14, 2011
                      Manchester, MD
                      Local Time:
                      7:15 AM
                      Exactly - the trailer will have brakes on both axles. Install a brake controller. Go to a big empty lot and dial it in, making several stops, both hard and soft - starting with soft. You can feel when you don't have enough trailer brake, or when you have too much.
                      • Agree Agree x 2
