Pushrods And Trick Flow Heads
Small Block Mopar Engine
  1. 12many
    12many Well-Known Member
    1,635
    2011
    Dec 14, 2016
    South Carolina, Thank God
    Local Time:
    7:56 AM
    Who’s running (or has mocked up to check) the Trick Flow heads for pushrod clearance and what rockers are you using? Rocker shafts directly in the stands, or moved up, towards or away from the valves? What diameters and or tapers. Details and pictures encouraged, would be interesting to see what others not using the recommended Harland Sharp components encounter.
  2. CRUZE 418
    CRUZE 418 FABO Gold Member FABO Gold Member
    515
    201
    Mar 11, 2019
    Illinois
    Local Time:
    6:56 AM
    I have PRW stainless roller rocker arms on my Trickflows. The ratio is 1.6. It's a whole kit, rockers, spacers, shafts, studs and 2 test push rods to measure for your pushrod length. Got mine through Mike at B3 Racing. He can set you up for a geometry kit too.
    • Like Like x 2
    • 12many
      1,635
      2011
      Dec 14, 2016
      Local Time:
      7:56 AM
      Waiting on my correction kit, thread really is just for anyone who has the TF’s to post on pushrods they are using and what if any clearance issues through the heads they may have had. Oh, and pictures if possible
    • CRUZE 418
      515
      201
      Mar 11, 2019
      Illinois
      Local Time:
      6:56 AM
      Well, you have to measure to see what you need. You say that you are waiting on a correction kit, how did you measure for it?
      I have Hill's Bros 5/16" pushrods, special made for my one off cam. If you haven't done your homework on this, hope you don't run into the oiling problem with your cam and lifter combo.
    • Toluene56
      Toluene56 Well-Known Member
      930
      717
      Nov 9, 2009
      reno
      Local Time:
      4:56 AM
      Comp 1622-16 rockers, trickflow pushrods can't remember the length, but they're hardened one piece 5/16.. more than enough room with 640 lift solid roller. IMG_20190606_181802073.jpg
      • Like Like x 1
      • CRUZE 418
        515
        201
        Mar 11, 2019
        Illinois
        Local Time:
        6:56 AM
        I don't read anything about speedmaster heads. You asked for and I told ya what I had on my Trickflows.
        If you want to take the low road, have a good ride, but not at my expence.
        • Thanks! Thanks! x 1
        • Agree Agree x 1
        • 70aarcuda
          70aarcuda Master Hoader of SBM FABO Gold Member
          16,135
          4793
          Jan 16, 2005
          las vegas
          Local Time:
          4:56 AM
          Crane 1.6 on intake...Crane 1.5 on exhaust...bolted to the pedestals....pushrods are Smith Bros...5/16 .083 wall...7.71 inches long...
          • 70aarcuda
            16,135
            4793
            Jan 16, 2005
            las vegas
            Local Time:
            4:56 AM
            got a set of ported SM on 360 .070 overbored...running old old old MP 590 cam...just think how much faster it would be with a newer camshaft....lol
            Ran a best of 10.462 @ 125......so yeah SM heads do work....
            • Like Like x 2
            • Agree Agree x 1
            • 12many
              1,635
              2011
              Dec 14, 2016
              Local Time:
              7:56 AM
              Hopefully this thread will just give anyone with the TF’s an opportunity to simply post what they ended up with regarding pushrods, and give additional details if they like. Nothing more. Simple:)
              • DrEamer
                DrEamer I suffer from cars on the brain!
                458
                597
                Mar 9, 2019
                Oregon
                Local Time:
                4:56 AM
                I'm running 1.6 PRW Rockers with the correction kit from B3 as well. The pushrods are Smith Brothers 5/16" x 7.100 set up for pushrod oiling. Smith Bros said with the shorter length,and street use hydraulic roller cam, (.560 lift) there was no need for a 3/8" units.
                • Like Like x 4
                • CRUZE 418
                  515
                  201
                  Mar 11, 2019
                  Illinois
                  Local Time:
                  6:56 AM
                  I may have misspoken, Smith Bros pushrods.
                • 12many
                  1,635
                  2011
                  Dec 14, 2016
                  Local Time:
                  7:56 AM
                  Looks like an early pattern is developing here favoring 5/16” pushrods. I’m kinda hoping to hear from some 3/8” users myself.
                • dartindanno
                  dartindanno Well-Known Member
                  338
                  466
                  Aug 25, 2011
                  Kenosha, WI
                  Local Time:
                  6:56 AM
                  I used Mancini 1.6 rockers Mancini Racing Aluminum Roller Rocker Arm Kit and Smith Bros 3/8 push rods but don't remember the length. If you need it just holler and I'll look it up when I get home. No correction kit for the rockers but they fit well and had a nice sweep IMG_0753.jpg IMG_0767.jpg IMG_0784.jpg
                  • Like Like x 2
                  • 12many
                    1,635
                    2011
                    Dec 14, 2016
                    Local Time:
                    7:56 AM
                  • dartindanno
                    338
                    466
                    Aug 25, 2011
                    Kenosha, WI
                    Local Time:
                    6:56 AM
                    The 7/16-20 x 5/16 ball adjusters are designed for use with Cup & Ball style pushrods. The Mancini rockers are made by Harland Sharp
                    • Agree Agree x 1
                    • flyfish
                      flyfish C8H18+N2O = :-D
                      2,200
                      792
                      Apr 16, 2007
                      Indy
                      Local Time:
                      7:56 AM
                      Why? If 5/16 work, why would you go with a thicker (possibly heavier) pushrod and potentially have clearance issues? I have used Smith Bros 5/16 pushrods in my last 3 engines, riding on solid roller and large flat tappet cams, no issues at all.
                      • Like Like x 2
                      • Agree Agree x 1
                      • 12many
                        1,635
                        2011
                        Dec 14, 2016
                        Local Time:
                        7:56 AM
                        From what I’ve gleaned here and from tech Articles is that you want the stiffest pushrod you can fit, the Weight concern is typically on the valve side, so a heavier pushrod is not an issue. Again, this is strictly info Ive found here and elsewhere.
                        • Like Like x 2
                        • Agree Agree x 1
                        • dartindanno
                          338
                          466
                          Aug 25, 2011
                          Kenosha, WI
                          Local Time:
                          6:56 AM
                          12many I can't wait to hear how you run this season, keep us posted
                        • Phreakish
                          Phreakish Well-Known Member
                          1,155
                          741
                          May 28, 2015
                          N. Idaho
                          Local Time:
                          4:56 AM
                          I'm running prw 1.6 stainless rockers as well, with 3/8" pushrods. Hydraulic ft cam (around 0.600 lift, measured) with lunati microtrol lifters. Clearance to the pushrods is tight, I really had to triple check my rocker shims because being off 0.020" was enough to cause concern. I had one rod rub during breaking, but only just barely. I re-shimmed that rocker and haven't had a repeat.
                          If I were to do it again, I'd go solid ft and 5/16 pushrods.
                          • Like Like x 1
                          • mopar65
                            mopar65 Well-Known Member
                            2,025
                            1885
                            Mar 23, 2008
                            Laquey MO
                            Local Time:
                            6:56 AM
                            I am useing PRW 1.6 roller rockers and mikes at B3 shim kit. Smith brothers 3/8 th push rods. With push rod oiling. Which are very close but they work. I am running a comp 550 soild lift cam. If I build a magnum 426 stroker engine, I will be useing my trickflow heads but will be switching to a solid roller cam
                          • lead69
                            lead69 hopeless car junkie
                            1,404
                            550
                            Nov 5, 2006
                            Vancouver,Wa
                            Local Time:
                            6:56 AM
                            No pics but I have the mancini 1.5 rockers with smith bros 5/16 pushrods (no correction kit) and they are close. I did the tape test and they passed but I don't think 3/8 would clear on my build.
                            • Thanks! Thanks! x 2
                            • B3422w5
                              B3422w5 Well-Known Member
                              1,441
                              1441
                              Feb 9, 2017
                              Portage michigan
                              Local Time:
                              7:56 AM
                              there is always an advantage using as thick a pushrod as you can get to work.
                              On my W5 deal i had 3/8 intakes and 7/16 exhaust pushrods
                              • Agree Agree x 1
                              • jbc426
                                jbc426 Well-Known Member
                                1,962
                                763
                                May 30, 2007
                                West Coast
                                Local Time:
                                4:56 AM
                                Just another thing to check. I went with Manton Stage 5 - 7/16ths pushrods in my RB, and had to increase the relief on the B3 spec'd custom rocker arms next to the adjusters to gain more clearance for those fat pushrods. You can see the proximity of the big pushrods on the 3rd rocker back in the somewhat blurry photo. My valvetrain has never been so smooth and quiet at all rpms.
                              • moparstud440
                                moparstud440 Well-Known Member
                                332
                                113
                                Aug 13, 2005
                                Keymar, MD
                                Local Time:
                                6:56 AM
                                My dad just assembled his using Mancini 1.6 rockers and he used their 5/16" cut to fit pushrods. He didn't have to cut them any, just assembled and they worked out for his combo. Undecked block, solid flat tappet cam, didn't use any shims under rocker shafts.
                                • Like Like x 1
                                • yellow rose
                                  yellow rose Overnight Sensation FABO Gold Member
                                  27,600
                                  23856
                                  Jun 19, 2015
                                  Central Washington
                                  Local Time:
                                  4:56 AM
                                  That is a MASSIVE correction right there. How many guys are running the same stuff uncorrected and wondering why their valve train is pissed off.
                                  • Agree Agree x 2
