PVC "valve hose" / valve cover breather hose
SlantedMark4
'74 Valiant 225 /6
Switzerland
I need to replace the PCV valve and the valve cover breather. The hose that leads from the PCV valve to the carb turned into a swiss cheese when I removed it so I need a new one. Can I use any hose for that purpose? Same question for the hose that leads from the breather to the air filter box.
I believe the valve cover breather is filled with wire mesh. You may just be able to clean it by spraying inside with something like brake clean.
I used regular heater hose for the hose from the valve cover breather to the air cleaner and 3/8 fuel hose for the PCV hose. Not correct, but it works and has been on there about three years.
